R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Tap into 12v outlet.
Old Nov 4, 2017 | 01:17 PM
Mpolarisf's Avatar
2011 R350 4Matic
Pretty basic here, need to tap into 12v wire in center console that runs to the 12v outlet below vents, 3 wires going to it. Orange, blue/black, and one small grey/white. I have a test light, but no where to grab a ground at in this thing to test. Anybody know which is pos/neg?
Old Nov 6, 2017 | 08:46 AM
efzauner's Avatar
2005 C240 2011 R350
There is no direct ground on the console cigar lighter.
Black Blue is +12v connected to fuse F46
Brown goes to the lighing/accessory SAM which will be connected to ground via a switch or transistor circuit to allow power to flow.
Grey/White is lighting.
You can get a DVM for under $20 which would help a lot in these situations..
File Type: pdf
Old Nov 6, 2017 | 08:52 AM
Mpolarisf's Avatar
2011 R350 4Matic
Thanks for the help, I've got it sorted.I installed an additional outlet to power a fire tv stick and hdmi to av converter for the rear entertainment. Works like a dream. Where can I get that... is it a dvm or dvd?
Old Nov 6, 2017 | 10:14 AM
efzauner's Avatar
2005 C240 2011 R350
its a DVM Digital VoltMeter Or more commonly DMM Digital Multimeter.
