R350/W251 4Matic Shuddering at mid RPMs
- Motor mount replacement (both driver and passenger sides)
- Transmission mount replacement
- Transfer case chain replacement (This did fix a chain slippage issue, but not the shuddering)
What else should I be looking at in order to troubleshoot this further? I did the above repairs myself, and I'm trying to avoid going to the mechanic since I have four hungry mouths to feed.
Thanks in advance!
Brad
Thanks!
You could install a new flex coupling and rear prop shaft yourself, and take it for a test drive. If there is no vibration, job done. If there is vibration you can:
1. Take it to an independent shop for balancing
2. Use the "hose clamp trick" to balance the driveshaft. Google it.
The option you choose depends on how you want to maintain the vehicle, and your budget.
Thanks!
From what i've read on other forums about these transmissions, it's a good preventative measure. Over 200K miles, they become quite deteriorated. Deterioration is acelerated if the torque converter is locking properly allowing for increased slippage which creates heat. Will update this summer when I tackle the job.
When i crank it, the motor feels like its rocking from side to side.
Not happy and afraid going to cost more than the car
