R350 Lower Control Arm Rear Bushing Replacement
The rear bushing on my right lower control arm is leaking fluid (see pic 1). That bushing is in a separate housing from the actual control arm. If I remove the 3 bolts in pic 2, can I easily get that housing and the bushing off the control arm? Also, does anyone know the torque specs on those 3 bolts to get them back on?
here it is. Attached the instruction for it with torques.
figure1a (01-16-2021)
You are welcome. I would spray some WD40 on the bolts day or two berofe, will help undoing them. And I was using a long breaker bar, came open with no problem.
I didn't know that bushing had oil in it; I thought it was just a rubber bushing.
Either way, let us know how it works out and take some pics.
