Tailgate not closing properly
So the tailgate on my R has been set to limit opening for the last however many years. It opens and closes correctly to that level. I have just disabled the limiter, and although the lid opens to the max, it will not close past that “halfway” point - it looks like it catches on that “halfway” limiter (while closing!), beeps, and goes back open. I can “help” it close and then I feel a resistance and once past that point it does close correctly, but looks like something is there.
Any advice on what to do with this? Do I need to disassemble the hatch?…
2006 R500
I had the same problem. What ended up working for me is doing a literal reset of the tailgate control unit using a clone STAR diagnostic system. I chose the options to install the tailgate control unit as a new unit, which ran it through a new calibration and that ended up working. A regular calibration from STAR diagnostic didn't work, and neither did flushing the hydraulic system. Flushing the system did clear out a lot of gunk though and I'm sure it made the tailgate perform better than it would have without it.
Tailgate Reset
2006 R500
If this is your only issue, I would recommend trying to find someone around you that has a STAR system. Only get a STAR system if you plan to do other diagnostics with it. In my case, I was reprogramming my R500 to tow a trailer, the dash for an aftermarket headunit, and some troubleshooting with the headlights in addition to the tailgate issue. I actually wasn't planning on using it for the tailgate at all, I just had some spare time and decided to experiment around to see if I could get it working properly.
As for flushing, it was the liftgate hydraulic system only. The pump is located in the spare tire wheel well on the left side.
How did you flush the hydraulic system? What liquid goes in it etc?
2006 R500
I got the MB Star C4. In my case, since I'm relatively tech savvy, I just got the C4 control unit and set up Xentry on one of my spare laptops using Xentry downloads I was able to find.
The procedure was relatively easy for me to figure out, but I know from experience that when it comes to software, what is easy for me might as well be an alien language to others. I'll have to hook it up and see what menu options I used. Basically you just have to find the liftgate control module and find the option that says use for programming new unit or something along those lines.
As for the hydraulic fluid, I used Pentosin CHF11S fluid. I removed the rear spare tire hatch so I could sit inside the car while flushing. The procedures I used are as follows:
Remove pump from housing.
With liftgate closed, drain fluid from the plug on the reservoir.
Fill with new fluid to approximately the same level as before.
Put plug back on. While holding the pump flat, cycle the tailgate a few times.
Repeat drain, fill, and cycling tailgate until fluid drained is the color of the new fluid.
samurnin (02-19-2024)
2006 R500
Thanks. I used to code BMW with NCSExpert and INPA cables, I can’t fathom the Xentry interface being any worse or harder to set up. Were you able to find the cables cheaper? Cause I can only find kits with a hard disk or with a laptop - I wouldn’t mind saving the hardware costs as obv I have a laptop lying around.
Understood. Thanks! Will give this a go
2006 R500
Disabling the clock being controlled by the head unit so I could set it manually in the dash menus. Probably going to be looking to disable navigation and compass next as they only work with the OEM nav unit.
Ahh very cool. Yeah I’ll be doing the same. Which HU did you get? I’m hesitating because I don’t want to lose rear view camera functionality, but the standard HU is pretty abysmal… And I know I’m detailing my own thread. lol
2006 R500
I got one of the Android ones. My R500 didn't come with a backup camera, so I installed an OEM-style one on my own. You should be able to get adapters to make it work with whatever aftermarket unit you get. You'll be looking for a Fakra to RCA adapter.
If you're ever looking for additional info, try looking in the X164 and W164 forums. Electronically they are identical to our cars.
2006 R500
Nope, the pump is contained in the black box on the left side of the spare tire wheel well and is fully accessible. I suppose if you didn't want to have to cycle the system, you would go through the procedure of removing the panels. I figured about 10 cycles was more than sufficient to replace most of the old fluid with the new fluid, and it doesn't use that much fluid anyways. I've done something like 20 flushes and barely used half a liter.
2006 R500
I didn't use the STAR system, I had the liftgate open and close a bunch of times while sitting in the trunk. Removing the spare tire hatch is necessary to work it from the inside, and the lines are a little short so the position will be a bit awkward. You'll see when you take everything apart.
Ok, so I opened the area up and this seems to be the pump. Would you mind sharing what you unplugged / what you did so I don't do anything stupid? I tried to find the procedure in WIS, but not unexpectedly, it's not really there. I think the screw with the blue head in the centre is the pressure release valve, right? What do you unscrew to empty the lines from the hydraulic fluid, and where do you inject it back? Do you need any special equipment for it? (syringes etc) Would regular power steering fluid work? I feel like I should unscrew one of the hydraulic lines on the left and close the hatch. That should leak all the fluid out, then attach it back, undo the blue headed bolt, and use some sort of a funnel to feed fluid back in, then open it so the lines get filled, and keep adding fluid. I think. Does that make sense? Thanks for your help!
2006 R500
Pull the entire pump out of there while leaving all the hoses and wiring intact. At the top of the plastic reservoir (seen on the left in your picture), there is a cap screw for draining/filling.
