R350 intermittent crank/start
I've had a issue for a little while. Sometimes the car doesn't crank the engine. First I thought I saw a pattern that it wouldn't crank immediately after driving for a little while and the car and engine was being warm but that doesn't seem to be the case, at least not every time. Car is a R350 with Keyless Go. Battery isn't exactly the best but my CTEK charger has no problem with it and even if the battery is fully charged the problem can occur.
What I've seen so far:
It seems that it always starts/cranks cold (not 100% sure of this but I think so).
When I press the start button and the car will not start I don't hear any "tick-tick-tick" like when the battery isn't charged and doesn't have enough capacity to start/crank. Actually I don't hear any sound when trying to start when it won't start.
I can drive, come home, park the car, kill the engine and then try to start immediately and it might not start but probably 9 times out of 10 it will start.
If I drive for a shorter period compared to a longer period hasn't been a factor as far as I've seen.
If the car will not start I can try multiple times to no avail but after a while it might start again.
If I've started it will not die and it behaves as normal and there is no warnings, no engine lights etc. on the display.
When I press the start button (without pressing the brake pedal) I can hear the fuel pump engage (as it normally always do).
What I've tried:
Switched keyfob.
I have removed the start button and used the keyfob to turn.
Charged the battery so it's full.
I've pulled and put back the relays in the front SAM to inspect them (all look good, no corrosion, moisture etc).
Example from one time some weeks ago:
Left home, car hadn't been used for a day and it's cold outside, drove for like 15-20 minutes, parked the car, came back after 15-20 minutes, the car will not crank. Waited for like 45 minutes and suddenly the car cranked, went home (which takes 6-7 minutes). Tested to crank car immediately after parking at home and turning off the engine, car will not crank/start.
Another day I left home, drove for like 45 minutes, went home, parked, tested to crank the car directly after parking, car starts without issues.
One question though, shouldn't I hear the relay ticking or the starter trying spin (make some sort of noise at least)? When it won't start it's totally quiet, only thing I can hear is what I think is the fuel pump everytime.
Thanks!
Thanks!
It was about an hour on a lift to swap out the starter. My starter did the exact same thing when it was dying. First it would start with slow starts when hot, and then afterwards it wouldn't turn over at all when hot.
I saw something similar on YouTube too.
I appreciate you.
It's a pity the original poster never bothered to respond after requesting everyone's assistance.
My suggestion would be to get a better scan tool such as a Launch X431 or similar.
You also seem to have some undervoltage codes. Is your battery and alternator fully operational? That means at least 12.0 v (engine off) and 13.7 v engine on. A small drop in voltage will trigger many of the codes shown on your list.
Have the battery and alternator tested as the start of ANY diagnosis. Once confirmed OK, Id getba better scan tool that is MB specific. Bluetooth style code readers simply can't pickup everything you want to see. Even the good ones dont sometimes.
Clear all the codes over multiple trips, scan again and lets see what you have then.
From what I read above, it could be solved by changing the starter. Or do I have to do some soldering? What is EIS and could someone redirect me to the YouTube video explaining the issue?
R500, 5.5l.
that doesn’t sound like the EIS problem. EIS problem is when you turn the key and it cranks only when the connector inside touches the electronic plate where it’s supposed to be soldered.
I understand you don’t have access to a obd scanner. You should get one or at least for the moment have it checked for codes. The EIS module will not cause weak starter when cracking. Only the no cranking could be the EIS. You could have multiple issues. You should get a OBD scanner.
