R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R350 – Cold weather starting issue, dashboard lights on but engine won’t crank
Old Feb 4, 2026 | 06:12 PM
rejson's Avatar
W251 R350
Hi everyone,I’m having a serious cold-weather starting issue with my Mercedes-Benz R350 and I’m hoping someone here has dealt with something similar.Even at temperatures around –12°C (10°F) or lower, the car often won’t start after sitting overnight. When I turn the key in the ignition, all the dashboard lights come on normally, but the engine does not crank at all. There’s no real attempt to start — it’s like the ignition or starter doesn’t engage.Earlier, I also had a warning message on the display saying:“Drive to workshop without shifting gears.”Because this seems to happen in freezing temperatures, I suspect the battery might be weak, but I’m not sure if that alone could also trigger a transmission warning.So the current situation is:Problems start already at about –12°CDashboard lights work normallyNo cranking, no startPrevious transmission warning messageHas anyone experienced something like this in cold weather with an R-Class? Could this all be caused just by a weak battery or voltage drop, or should I be looking at the starter, ignition switch, or transmission electronics?Thanks in advance for any advice.
Old Feb 4, 2026 | 08:25 PM
slawek's Avatar
could be bud ground connection , or weak battery .
Old Feb 4, 2026 | 09:00 PM
rejson's Avatar
W251 R350
I’ve started with the battery — I’ve already bought a new one and I’m currently waiting for delivery. I really hope this will solve the problem.
Old Feb 5, 2026 | 11:29 PM
slawek's Avatar
if your battery was older then 5 years then in the cold weather is no good.
Old Feb 6, 2026 | 03:05 AM
rejson's Avatar
W251 R350
I’ve been driving this car 4 years and I definitely haven’t bought a new battery myself. I also don’t know if or when the previous owner replaced the battery.
The new battery is scheduled to arrive on Monday. In the meantime, the car is currently immobilized and not drivable.
Old Feb 7, 2026 | 10:15 AM
Giancarlof's Avatar
R350
Something similar happened to me. One key would not start the car but would lock/unlock and raise/lower windows. Did not get a message about recognizing the key. But when I used our spare key it started right up. I too was advised to change the battery but it was not necessary.
G
Old Feb 7, 2026 | 02:32 PM
rejson's Avatar
W251 R350
I connected the car to a diagnostic computer and it showed errors related to the EZS and ISM, and the faults could not be cleared.
I then removed the radio panel to access the ignition switch, unplugged the wiring connectors from it briefly, and plugged them back in. This allowed the ignition switch to re-initialize, the errors to be cleared, and then I was able to start the engine.
Everything points to an issue with the ignition switch, and it looks like I will need to replace it.
Old Feb 7, 2026 | 07:36 PM
slawek's Avatar
when you plug and unplug connectors make sure you have a CRC spray handy it could be as simple as the bud grounding issue .
Best
