R63 AMG (W251) 2007 - 2013 Discuss the R63 AMG.
R63 Project...
Old Sep 8, 2016 | 07:38 AM
WallyR350's Avatar
R63, X5M, FJ
R63 Project...
I am throwing this out there to anybody that may be interested. I have a 2007 Silver R63, that decided to eat it's own motor. In July on the way home from vacation a valve broke off and made contact with the piston which killed the whole motor.
After a little research I found there had been similar issues with the buckets and valves on other 63AMG motors so I decided I would not replace the motor with another used motor. I did some research and talked with the guys at Weistec to have them rebuild the whole motor from the block up, because they had address most of the common problems with the motor. So that is the direction I am heading, however it's a going to cost around $ 22k so I can not say that I running that way.
Currently the R is parked and waiting for funds to start the project. If somebody wants to buy the R from me I am willing to sell it, it has around 78,000 miles and beside the motor is in excellent shape inside and out. PM if you are interested.
http://weistec.com/company
Old Oct 1, 2016 | 04:07 AM
bobpowell1979's Avatar
2013 Subaru STi
Hey WallyR350 I'm interested PM sent.
Old Oct 6, 2016 | 11:36 AM
AMGoneday's Avatar
R63
PMed
Old Oct 9, 2016 | 03:05 PM
davidrap's Avatar
Mercedes 560SEL
R63 Project
Hi Wally,
PM Sent!
Thank you.
Old Oct 12, 2016 | 05:26 PM
Mark Slodyczka's Avatar
S600
R63 project
Hi interested thanks
Old Oct 12, 2016 | 06:46 PM
C1Forged's Avatar
Former Vendor of MBWorld
CS55
Why not do a combination of the two? Instead of a full re-build that will require all new internals, and maybe even a new head/block due to damage; get a used engine for cheap and replace the heads, or upgrade the valves. Should be much cheaper than $20k for a full engine build.
Old Nov 16, 2016 | 11:07 AM
eroyaln's Avatar
toyota venza
Wally...
I sent you a PM regarding your R63.
Have you made any decisions on what you're planning on doing?
Old Dec 24, 2016 | 08:41 AM
WallyR350's Avatar
R63, X5M, FJ
Hi Guys,
My plan was to sell the R to another enthusiast in search for an R for their wife and kids. As you know it needs a new motor, but I never found anybody interested in taking on the job. I think I responded to everybody's PM, sorry to any that I did not.
I had the engine pulled out this week and I drive it down to Weistec. The project has begun, first let me say these guys are awesome. We toured their facility and were very impressed. Best part is there is an all wheel drive dyno there for testing the R once we are done. We are doing a full engine build top to bottom in prep for a stage 3 super charger, and bullet proofing the transmission to match the power. Power should be around 850ish HP, yes that's right. And built to be a daily driver.
When we are done it will be the fastest R in the world. Below are some pictures from the trip.
Attached Thumbnails R63 Project...-w-1.jpg   R63 Project...-w6.jpg   R63 Project...-w2.jpg   R63 Project...-w5.jpg
Old Dec 24, 2016 | 08:49 AM
WallyR350's Avatar
R63, X5M, FJ
Attached is a picture of there Stage 1, 2, & 3
Tough decisions.
Old Dec 24, 2016 | 09:34 AM
WallyR350's Avatar
R63, X5M, FJ
Here's some details on the engine build:
-M156/M159 Forged Pistons and Billet Rods:
Maintains Factory 11.3:1 Compression
Optional Ceramic Coated Piston Tops
Teflon Coated Piston Skirts
Billet 4340 Connecting Rods
Improved Wrist Pin Design
Performance Ring Set Included
Increased Power Capacity and Heat Dissipation
- Weistec Engineering M156 Head Stud Assembly
-Designed with ARP 625+ Hardware ARP Camshaft Adjuster Bolt
-Weistec M156 ARP Camshaft Cap Bolt Set
-SLS Valve Tappet (Lifter)
-M156 Gasket Set
Includes complete gaskets and seals for rebuild.
All OEM Gaskets.
-M156 Crank Sprocket & M156 Timing Chain
-M156 Oil Pump & chain
- Engine Assembly Labor
Includes:
Machining to Cylinders
Balancing of Rotating Assembly
Polishing of crank
Complete Assembling of Engine
-M156 Timing Chain Tensioner
-Weistec 722.9 Bullet Proof Transmission, 4WD
And of coarse a supercharger.
Old Dec 24, 2016 | 12:27 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Exciting to see you are keeping it and doing this.
keep us updated - I'm interested in doing their m157 upgrades but so many options other there it's overwhelming.
Old Dec 24, 2016 | 04:20 PM
AMGoneday's Avatar
R63
How will the transmission hold it together? I would have went the same route as you!
Old Dec 26, 2016 | 08:52 AM
WallyR350's Avatar
R63, X5M, FJ
They rebuild the tranny and upgrade the clutches for 1000HP, to match whatever power you decide to throw down. If I do stage 3 it will be around 820 or so.
Old Dec 27, 2016 | 10:54 AM
NYCBenz's Avatar
6x6 | 4x4
Wow, pretty incredible.
Good Luck!!!!
Old Dec 27, 2016 | 10:58 AM
Chedman13's Avatar
Does anything have to be done to the transfer case?
Old Feb 5, 2017 | 02:01 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Any updates?
Old Feb 20, 2017 | 12:25 AM
WallyR350's Avatar
R63, X5M, FJ
Originally Posted by AKnight55
Any updates?
They are getting close to finishing the rebuild, I was told end of the month. So we are getting close. While I wait I am having the rims re-finished and powder coated gun metal.
Old Feb 20, 2017 | 08:48 PM
AKnight55's Avatar
Will you do 1/4 mile run after the build?
Old Feb 21, 2017 | 05:27 PM
WallyR350's Avatar
R63, X5M, FJ
Sure, I don't expect a dramatic improvement, unless I supercharge it.
The engine will be done Friday! I got these pics from the builder today:
Attached Thumbnails R63 Project...-r63-built-1-4.jpg   R63 Project...-r63-built-1.jpg   R63 Project...-r63-built-2.jpg   R63 Project...-r63-built-3.jpg
Old Jun 9, 2020 | 01:23 PM
WallyR350's Avatar
R63, X5M, FJ
Anybody want this beast, I am going to list it and sell it. It has 90,000 miles on it and is in excellent shape.
Old Jun 9, 2020 | 01:46 PM
Chedman13's Avatar
Nice! Asking price?
Old Jun 11, 2020 | 02:08 AM
rbtmak's Avatar
GLS63, R63, Cayenne Turbo & GTC4 Lusso
Hey WallyR350! If you remember me, I'm the guy who had your R63 in Vancouver before you purchased it. We met up in StarBucks and I gave you the ZR3 control unit for the car years ago.
Tell us about your Weistec modded R63! A few months ago, I bought my second R63 with only 9,500 miles - I'm in the process of building it up now going along the same route as you.
Cheers!
Old Jul 1, 2020 | 11:22 AM
AMGoneday's Avatar
R63
Did you list yet?
Old Aug 5, 2020 | 05:18 AM
TonyA's Avatar
Asking price?
Old Aug 10, 2020 | 01:57 AM
camv10's Avatar
‘02 E55 Wagon, '05 E55 Wagon silv, '05 E55 Wagon blu, '07 R63, '08 G55, '14 E63S Wagon
I am a serious buyer please contact me.
