Battery Lamp, BAS, and Suspension lamps won't turn off - 1998 CL 600 81K miles
Any help would be appreciated. Thanks.
with engine running and alternator excited ie rev at 1800-2000 rpm should be getting almost 14 volts at the battery.
Your voltage regulator may be shot
if you charge the battery fully and don't use headlights drive in daylight you can travel a few miles and have most auto part stores hook it up and test alternator function.
If it is the alternator VR you can replace it. If it is the alternator $238 at autohausaz.com
