Auxiliary Battery, AGM
Old Dec 23, 2020 | 08:36 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
In swapping out my aux. battery located in the trunk of my '16 S550 coupe, there is a venting tube for it. This is an AGM battery, p/n 000-982-96-08, so why did MB vent it? It's a PITA to hook up due to limited space so I didn't do it. Now I'm having seconds thoughts.
Old Dec 23, 2020 | 12:07 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
The documentation that I have read indicates these batteries are vented with a valve that only opens to relieve over-pressure, should any occur, internally to the battery. The vent is only opened if there is an abnormal condition.
Old Dec 23, 2020 | 12:57 PM
Jud Chapin's Avatar
Thanks. Where can I find the documentation you have. Funny, I've owned a few Vettes, 70's & early '80's, and the battery was in the back storage area inside the car. No venting on those.
Old Dec 23, 2020 | 09:15 PM
Veteran: Air Force
Here's one that I got re. my SL.
File Type: pdf
Old Dec 23, 2020 | 09:31 PM
Veteran: Air Force
I had a '71 vette 454. I don't recall a vent either. But those had lead acid batteries so maybe the compartment (behind the driver's seat) had some vent to the outside air since those older batteries vented through the filler caps.
Old Dec 23, 2020 | 11:10 PM
Jud Chapin's Avatar
Great...Many thanks...
Old Dec 28, 2020 | 10:43 AM
Jud Chapin's Avatar
Well, it's been eating at me that I didn't rehook up the vent so I decided to have another go at it as I'd rather be safe than sorry. Amazing what a snap this job is of swapping out the aux. battery once you've done it. Anyway, I got access to the battery again and placed the plastic angled vent part with the tube connected into the battery. Then with the battery in place, I sprayed WD-40 on the tube and it slipped right in to the car's vent hole in the trunk. Without lubricant, it's tough getting the vent tube where you want it due to limited space. The whole job took about 45 minutes as opposed to a couple of hours the first go around. There's a lot of confusing info out there on doing this job including MB's WIS. If my aux. battery were to need replacment again, I'm sure I could do the job in 1/2 hour or so. Keep in mind this is for the S550 coupe but I imagine the S550 sedan is basically the same.
Of interest is what this battery is called. I see where just MB has several names for it including auxiliary, starter, and additional (WIS).
Old Dec 28, 2020 | 11:59 AM
Veteran: Air Force
Congratulations on a successful DIY jib.
Old Dec 29, 2020 | 12:54 PM
konigstiger's Avatar
'71 Pinto
There's a lot of confusing info out there on doing this job including MB's WIS. I see where just MB has several names for it including auxiliary, starter, and additional (WIS).
Attached WIS "Additional battery remove/install" docs for membership viewing this thread.
File Type: pdf
File Type: pdf
Old Dec 29, 2020 | 01:55 PM
Jud Chapin's Avatar
Thanks...I have WIS and have used it for years but unfortunately have had my ups and downs with it. I find it not particularly user friendly. In the case with the aux battery, it states to remove the right trunk panel for access and refers you to a section on how to accomplish this. Unfortunately, these instructions only show how to remove all trunk panels with no explaination regarding removal of just the right. Further, the most important step is missing showing how to remove the chrome trim at the opening of the trunk, or at least I couldn't find it.
Without first removing this piece, no panels can be removed. Actually, to remove the right panel, as I discovered on my own, just the chrome piece and the 2 bottom panels need removal which is not mentioned. If memory serves, an MB tech told me that they take WIS classes before using it.
Out of curiosity, have you done this job using WIS instructions only?
Old Dec 29, 2020 | 02:47 PM
'71 Pinto
Not disputing, WIS is not exact never has been just thought I add docs for those who visit this thread.
Old Dec 29, 2020 | 03:15 PM
Jud Chapin's Avatar
For those wishing to remove the chrome piece, the obvious first step is to remove the 2 retaining clips located on the black section of the trim facing the inside of the trunk. A flat bladed screwdriver works well here.
The final and much less obvious step is to pull straight up on the piece. It is held in place by 4 other retaining clips not visible from the outside. For access to the right panel behind which the aux battery is located, simply remove the 2 lower panels on the floor of the trunk.
