Hi and timing chain question.
The 14" wheels and tires look a little too 'weak'. Are the 16" wheels (I'll figure the tire sizes to adjust gearing) from newer MBs the same offset and bolt pattern?
Thanks,
Don
Personaly if it were my car I would do the chain soon.
16in, 8 hole wheels are a nice upgrade. If they are off an SL (R129) they will not fit, but I think W140 wheels with different tires will.
My advice - replace the chain and guides.
The MB CD manual SUCKS. It doesn't even cover the timing chain and guides! Any other source?
Don
It's a job you should go about gingerly the first time through as mistakes can be costly in both time and money.
Jonathan
http://jono.mbfans.net/Index.htm
Need parts? Give a call, I don't sell anything I wouldn't install on my own car.
404-805-1357
blueridgemb@gmail.com
Update...I have managed to change the guides and timing chain. This would be an easy job on a new car but on one whose bolts have not been removed in 21 years was a pain. I wonder why MB used allen heads on the alt. side and hex heads on the PS side. One of the alt. bracket allens rounded off. I ground down a larger allen wrench and stuck it into the rounded off bolt w/ some jb weld and left it there for a day....did the trick. Removing the guide pins was a nightmare. The bolt and washer method worked for all but one. The bolt broke off in the pin. The easy out broke off in the pin. Luckily it was the uppermost pin on the driver's side so I cut the guide off, cut the pin and tapped it out from the inside.
The only thing I have gained w/ the chain and guide replacement is peace of mind as the chain only had 2* of stretch and the guides were not brittle. I bent the old ones and they darn near folded in half before they broke.
Why isn't there a guide made like the tensioner guide...w/ metal backing?
