wheel bearing screwup!
89 420 SEL and 97 E320
I put new races and bearings in my 420SEL Friday night. Sunday I drove to work and back, when I got home I smelled a nasty "hot" smell and saw that the grease cap had blown off, taking the Mercedes center cap with it.
I don't know when it happened, but my best guess is that I drove about 10 miles with that cap off in snowy/salty/wet conditions.
First, anyone know why this would have happened? I filled the inside of the cap to the line with grease like the manual said, and it was fully seated.
And secondly, should I replace the bearings again, or just get another cap and repack the bearings?
Originally Posted by Hattaresguy
Ok I am far from a wheel bearing expert. But did you tighten and pack them properly? I have never seen a bearing cap blow off, they must have been really overheated!
I had forgotten to put in the radio static suppressor, and pulled the cap, put in the suppressor and reinstalled the cap.
I'm wondering if the cap is a one-time install.
I'm not sure that it "blew off" as I described it, just that it's gone, along with the wheel center cap. It could have been off balance and wiggled off... I don't know.
I guess I'll pull the wheel this evening and see if the spindal/bearings are burnt. That'll tell me if it got hot... before or after.
Originally Posted by golfboy
I haven't seen that before either. I did pack the bearings and then put extra grease in and around the spindal and inside the rotor hub. Then the manual calls for almost an inch of grease in the cap before you put it on.
Originally Posted by schwarzwagen
depends on if you deform the dust cap.
did you tighten the bearings to spec also?
As for tightening to bearing, I snugged the nut down until I couldn't turn the rotor (by hand) then backed it off 1/3 turn.
Well, the bearings are definately shot. I can't even get the rotor off the car!
Pulled the wheel and the caliper then tried to pull the rotor/bearings... they won't budge.
The rotor still spins just fine, but the outer bearing won't come out.
I even remounted the wheel, and tried to use the extra leverage to wiggle the bearing out... won't work.
Is there a puller tool for wheel bearings?
Why can't ANYTHING be easy?
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Why can't ANYTHING be easy?![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
something out of the ordinary is going on here because the outer bearing should be removable quite easily. ie, with your fingers. sometimes the inner sealing ring doesn't want to free from the spindle, but even then you can get it free by just pulling on the rotor with some force.
Spindle looks fine, but I still don't know what happened so I'm a little nervous about reinstalling the new stuff.
I need an alignment anyway, so I'm going to put it together, take it into my mechanic and have the alignment done and have him check the bearing setup.
Originally Posted by mleskovar
Never done wheel bearings on a W126 but the adjustment technique you used is new to me. Is that the accepted method? Some wheel bearings need a slight preload but most are tighten until play is removed only.
Unfortunately, there haven't been any responses about it.
1 Post
1987 300SDL aka the "Money Pit"
I did my front wheel bearings just like you did, tighten them up and back off about 1/3 of a trun. 20k miles later and they are still fine.
Actualy according to the FSM you are supposed to weigh the grease. MB gets a little nuts sometimes but I guess on the Autobahn at 150+ you have to.
Thanks man, that makes me feel better about it. I've been driving it around town for the last week, but I haven't had the nerve to go too far away from home until I knew I had it right.
