Performance Air Filter (1984 500SEC)
A friend recently removed the airfilter (briefly!) from my '84 500SEC to demonstrate the engine sound without it. I was literally blown away! He suggested replacing it with a sports/ high performance air filter.
What impact (besides engine sound) will this have? Will it increase fuel consumption?
Can anybody suggest such a filter and where to get it.
(Is it something like this that I'm after? http://www.knfilters.com/search/prod...px?Prod=E-2872)
Thanks in advance,
Les
Since then I have interchanged the stock filter with the pod to see if I could tell much difference, there is a little bit more throttle response with the pod fitted so it gives the impression of more power but that is about it, also the exhaust has a nice 'crackle' when the throttle is lifted
The only major noticable difference is in the sound, with the pod producing a quite audible suction sound, turning into a roar under hard acceleration
I expect I'll go back to the 'pancake' airbox with perhaps a K&N filter inside as I'm worried the pod is letting to much fine particle debris into the engine
Thanks in advance,
Les:
I tried a K & N filter into the aluminum "pan" and did not notice a lot of difference. It is safe to use. Even after oiling the filter the oil cannot drip down into the intake (in newer cars this can ruin the "hot wire" in the intake). I then took off both resonators (located under the rear seats) put in twin straight pipes and find that it makes a difference. Quicker response and a sporty V-8 sound.
I think using the mushroom head pod is not a good idea as it has to stay inside the engine bay. The 560 SEL has twin snorkels going all the way to the front of the car to suck in cold air.
Just be Very careful in oiling them..I like to give the oil on the filter a few hours to migrate before checking/re-oiling.. The extreme propensity is to over oil :-/
Jonathan
someone care to explain??
Anyway, from what I know, K/N filters are reusable. You clean them then you have to apply a special K/N oil to the element which aids in trapping dust particles. They actually are supposed to work pretty good. But I just do not have the patience to wait the time needed to let the oil work it's way into the filter.
Vacuum the whole aluminum pan too. Lots of dead insects, dirt and salt.
Finish the whole thing by spraying down the butterfly with a fuel injector cleaner while someone revs the engine. Make sure you are not standing in front of but at the side of the car so you do not get run over.
As for feeling a K&N you won't..but on the dyno I always see @ least a couple of HP when I swap from standard paper.. Tested on 5 different 560's now, results always the same.
Jonathan
Jonathan
