ktronic to carburator conversion
vacuum it have
ps: it for science project
and do some adjustments like oxygen senser stand alone system
and do some drilling to the air intake for a hose or two
It is also pretty easy to adjust the richness with a #3 Hex key, but rough idle and hard starting will be an issue. I guess if you have an on-the-fly switch it should work. Just use premium since you'll be running extra hot.
Building a more fuel efficient engine requires decreasing brake specific fuel consumption.
I might be off base, but it seems that's what you're trying to do. If this is indeed the case, I'd suggest a little more research into the combustion processes, and the influence the mechanical design of internal combustion engines has on it. The amount of manifold vacuum an engine develops doesn't correlate to its fuel efficiency.
neat is it not
