S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
87 420 sel rough, high idle
Old Jul 13, 2010 | 09:51 PM
crazycooter's Avatar
420 sel
The car starts easy enough, no air leaks(checked w/propane), it idles @1250RPM and shakes a good bit. I couldn't narrow it down to 1 cyl. Air control valve works, and it runs great once off idle. I checked the air bypass valve, it checked out. Also has weak spark which seems to get a lot stronger and the stumbling seem s to stop when I unplug the ignition control module. Plus are new and wires check out on an ohm meter. What's next???
Old Aug 10, 2010 | 03:04 PM
GRIMSTONE's Avatar
380 SL/ 240D stick/ 420 SEL
Idle is high. Check one plug wire at a time it could be one is crossed!
