S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
84 500sec stumbles only on heavy acceleration?
Old Jun 29, 2011 | 11:26 PM
NI500SEC's Avatar
84 500sec
84 500SEC stumbles only on heavy acceleration at about 3700 RPM and progressivly gets worse as the rpm goes higher, this all started after a mechanic fixed it when it started to suddenly idle very low, and run very rough.
Old Jul 15, 2011 | 11:24 AM
48hp's Avatar
500 SEC, SEL, SL
What did your mechanic fix?
Could be any number of things. Clogged fuel filter, timing, vacuum leak,
Old Jul 18, 2011 | 11:09 AM
woodboat's Avatar
1987 300SDL
High rpm stumble that gets worse with increased rpm is usually, not always , fuel related. Once I had a worn distributor upper bearing in a chevy that did this but it was more like it hit a wall and wouldn't accelerate past a certain rpm. What did the mechanic do to correct the idle issue?
