1982 300sd difficult start
When that is done, if the battery and solenoid cables are tight.
Try jumping the small wire attached to the solenoid with a Phillips screw, over to the battery cable.
If the engine cranks normal, the issue is 90% odds your Neutral Safety Switch has failed, or 10% odds the ignition switch is bad.
roy@pelicanparts.com
