S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!
Old Jun 10, 2014 | 10:40 AM
wrightbenz's Avatar
SL55 SLK 320
I am chasing this problem down. The car drifts at idle and if I push the accelerator to the floor there is a hesitation and the car never really gets going. Doesn't reach redline. If I let off a bit and it gets into the next gear it pulls hard and quick.
What I have done so far.
New Voltage protection relay
New fuel pump relay
replaced injectors and seals
Cleaned Idle control valve
The car is running much better than when I bought it just not quite there.
I am guessing I have a small vacuum leak somewhere causing the idle to drift but not sure. Building a smoke machine to check for leaks.
May also be low fuel pressure I guess, need to check that. Possibly pressure regulator?
Help me out here guys
Attached Thumbnails Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!-imag0814.jpg   Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!-imag0816.jpg   Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!-imag0813.jpg   Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!-imag0818.jpg   Flutuating Idle, acelleration poor pics of the new car IT is nearly perfect!-imag0817.jpg
