420 ignition cutting out
e320 2000
I have a troubleshooting question on my 420. After bringing it out on the road after laying it up for the winter, I started the car and idled it for 20 minutes in my driveway. All systems OK. Then after 2 miles into a test drive, the car sputters and within 100 yards simply cuts out. I could start the car but it would not stay running for more than 1 second or so. The car has fresh gasoline and a new fuel filter installed before the test drive.
Any ideas on what is going on here?
1994 E320
After having left it idle for months during the winter, water vapor could have formed inside the fuel tank and made its way into the injection system. Try some "dry gas."
suntubi, tell me how you made out with your benz, i have the same problem and will try to take care of the water in the tank as well, i didn't suspect that the water could do that to my 600sel
e320 2000
Thanks for the note on dry gas. I'll give it a try. The fresh gasoline I put into the car was an alcohol blend (ethanol ). I thought that might have helped with the water in injectors.
Are there any purge points up in the engine compartment?
Would the quick cut out be an indicator that both fuel pumps failed?
1994 E320
If both fuel pumps failed the engine would not be able to start at all. If you can get the engine to run for a few minutes (like you said), then one of the pumps must be functional.
e320 2000
Thanks for the suggestions but ......,
After replenishing the fuel and using some dry gas, still no luck in firing the car up. Anyone have any suggestions on next steps ( besides towing to a mechanic)?
my mercedes had the same problem,i had to replace air flow meter, catalityc converters were pluged, and the air flow meter conectors had cracked isolation on the wires, check the harness,
e320 2000
Cost? Rotor about $37. Cap $125 or so, wires could go $80 - $100, Catalytic converter $ stratosphere, flowmeter ???,
But what's money when you drive a classic?
