S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Throttle issues.
Old Apr 10, 2004 | 02:12 AM
GTR John's Avatar
1990 500SL / 1989 560 SEC
Unhappy Throttle issues.
The car goes good. No doubt about it, but when we took the top intake cover off, my pops noticed that the throttle pedal when pushed down all the way does not open it up full throttle. For example; About 4 inchs of start to finish, when the pedal is pushed all the way down, it only opens about 3 inchs open but you can pull the throttle more open with your hand. I hope you guys can understand what I am saying. If not than I will just take pix.
When of our customers wh ois a Mercedes mechanic for the dealer said somethign about how the rest of the throttle is controlled by the cruise control. The cruise control does not work on the car, because the car may have some comp problems.
Any help guys. I wanna feel the REAL power of this beast! Get it running well and than I will dyno it. We have a friend with a dyno at their shop. I will dyno the results!
Old Apr 11, 2004 | 02:33 PM
Jer's Avatar
Jer
1994 E320
There could be too much play in the cable, which means the first few inches of pedal movement will not open the throttle. Is this the case?
Also, is the air intake plate resting at the "zero" position, or somewhere higher?
