S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
126 tune up questions, please advise:
Old Apr 20, 2004 | 10:01 AM
bcmbcmbcm's Avatar
380 SEL 1982
Hey folks,
checked out thepartsbin, and I have a couple of q's for an 83 380 sel:
1. Is the coolant Z8003-69600 a pre-mix or can I cut it 50-50 with water?
2. What type of spark plugs are best for this application:: thepartsbin lists 3 types, 2 types of Bosch (I assume one is normal, one is platinum, and an NGK 5ES)
I don't mind spending an extra $1 per plug, but I have found that getting the wrong plug is worse no matter what the cost.. just want to get the right one.
3. Is there a special ATF that this car requires?
4. Is there a special brake fluid that this car requires?
5. Should I change rear end fluid, and if so, with what type?
Basically, I am bringing a low-mileage original car out of hibernation and want to change all fluids, etc.
Old Apr 20, 2004 | 05:56 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
I can answer question #1.
If it's the Mercedes's coolent, then you'd need to mix 50/50. It should say on the outside of the container. Have fun
Old Apr 20, 2004 | 11:50 PM
Jer's Avatar
Jer
1994 E320
I'd go for the Bosch copper core plugs. Platinums are typically not recommended for MB (at least the older ones).
Many people like using Redline synthetic ATF, but I just use the standard stuff from Febi-Bilstien, available through PartsBin.
I think brake fluid is DOT4, but check your manual to be sure.
When you say "rear end" are you talking about the differential? If so 85W-90 is what you need. Synthetic is also popular.
Old Apr 21, 2004 | 01:16 AM
bcmbcmbcm's Avatar
380 SEL 1982
synthetic atf
is this the synthetic atf you are talking about?
http://www.redlineoil.com/products_gearlubricants.asp
and if so, how do I get all of the old fluid out of the lines?
Yes, I was talking about the differential. 80-90w dino it is!
Brett
Old Apr 21, 2004 | 09:39 AM
Jer's Avatar
Jer
1994 E320
That's it. You have to remove the drain plugs from the pan and the torque converter to remove all the fluid. Be careful when you fill up. Do not use too much or too little fluid, and do not use towels to wipe the dipstick. Use your fingers!
Old Aug 25, 2004 | 07:17 PM
peace's Avatar
i gotta worn you about the coolant. dont use the green stuff use the yellow stuff from the dealer. i heard it was a bad idea to use the green coolant.
