S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Considering a 420SEL
Old Apr 29, 2004 | 07:28 AM
zymurgist's Avatar
Question Considering a 420SEL
I found a 1988 420SEL with 116K miles. I'm going to look the car over this weekend before I decide whether to buy it. The owner has a mechanic friend with a lift, and I will be able to look it over from bottom to top. I would like some pointers on what I should be looking for that is particular to this model.
So far, my research indicates that the condition of the timing chain tensioners is important. How long are they expected to last? Should this have been done to this car already?
Any other information would be appreciated. I don't know much about Mercedes cars, but I'm a reasonably knowledgeable amateur mechanic, having disassembled and reassembled a Corvette in my garage.
Old Apr 29, 2004 | 09:26 PM
Jer's Avatar
Jer
1994 E320
The timing chains last a long time, however, the recommended replacement interval is 100K miles. Check if the chain has been converted to the double-row setup. When the engines were released with a single-row chain, they were prone to fail and cause serious engine damage. A double-row retrofit is free of charge (recall campaign).
Check the condition of the suspension, namely bushings. They wear out over time and can affect ride quality.
Good luck!
Old Apr 29, 2004 | 09:35 PM
bcmbcmbcm's Avatar
380 SEL 1982
recall?
are you sure about the recall for the double row conversion?
I have scoured this board and haven't heard anything about it..
that would be great, as I am facing a conversion myself.
don't think it is an issue though for this car, as I understand only 81-83 have the single row chain.
Old Apr 29, 2004 | 09:44 PM
Jer's Avatar
Jer
1994 E320
I am very sure this was a recall. I thought the newer models were affected, so check with a dealer to be sure.
Old Apr 30, 2004 | 07:54 PM
vwbuge's Avatar
'85 300SD (CA em.)
I can only offer you some advice as I am a diesel man myself. The most important single thing I can tell you is SERVICE RECORDS. As with any older MB this is important. Look for anything written down or receipts. Even if it is as small as an oil change. At least it shows that someone spent time on the car and cared for it.
Old Apr 30, 2004 | 08:47 PM
zymurgist's Avatar
Thanks for the advice. I didn't get to spend a lot of time with the owner last weekend, but he did show me the service book, and the original owner seemed to be pretty meticulous. The booklet was filled out and stamped on a regular basis. Don't know whether the timing chain/upper guides/tensioners have been done, though. I'm going to find out tomorrow.
Old May 8, 2004 | 07:49 PM
Florida Rog's Avatar
86 420 SEL
The double row chains were not an issue in 86 and up cars. After 1985, double row chains were installed at the factory. The tensioners and guides are more of an issue than the chain, although it is a good idea to change all at each 100K interval. It maintained, these cars are fairly bullet proof.
Old May 17, 2004 | 03:00 AM
izzodesh's Avatar
ML 55 and 420 SEL
i would def. check out the suspension and the AC if not fixed after 100k it will cost you over 4k to fix it..
and if u dont mind me asking...how much does he want for it?
i also have my car for sale in Potomac, MD
check the classifieds for my listing
but some info about it is:
1991 Mercedes Benz 420 SEL
Mileage: 116k
Mint Condition
One Owner-All Service Records
Clean CARFAX
LOJACK included
*NEW* AMG Rims w/ Bridgestone s03
Stock Rim w/ winter tires
OEM Euro Head Lamps
OEM Clear Turn Signals
New Tints
Kenwood Head Unit
Kenwood/Infinity Speakers
Dual Airbags
Antilock Brakes
Grey Leather w/Granite Metallic Paint Exterior
Seats are in Mint Condition w/ No Sign of Wear
Garage Kept
Non-smoker
New Bushings for Suspension
It is equipped with 4.2L V8, Automatic Transmission, Ice Cold AC, Driver and Passenger Power Seats, Power Windows, Power Locks, Power Mirrors, Power Sunroof, and Cruise
Feel Free to Contact me 24/7 at
973-271-5449
or email me at bikeswim101@hotmail.com
Pic:
Click for pic of my car
