S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1990 Mercedes Benz sl500 coolant temp 100 degrees Celsius
Old Jun 17, 2024 | 11:39 AM
atomlude55's Avatar
Hi there just picked up this 1990 Mercedes Benz sl500. It only has 49,000 original miles, just put in a new thermostat and fresh coolant. Along with a fresh oil change. It was a hot day but my coolant temp keeps going up to 100 degrees Celsius and stays there. Especially if I turn it off and on. Also my gas gauge just randomly quit working yesterday too am I going to need to have access to the fuel pump or behind the gauge cluster? Any advice is greatly appreciated.
Old Jun 18, 2024 | 10:26 AM
Chillguy1980's Avatar
2015 S550 4matic
Yea probably air bound and needs to be bled
was it same temp thermo?
not sure exactly but usually the gas float is in tank
Old Jul 21, 2024 | 09:58 AM
JohnLane's Avatar
222 S-65
Fuel level sensor in fuel tank. Test it with Ohm meter. If open it is junk.
Coolant temperature.... This vintage of MB is from ‘The bad old days’ when radiators got plugged up due to silicates in coolant back then. There is no flushing that ick out. The radiator gets replaced. With A/C on the radiator fan should vary it’s speed to speed way up as coolant temperature climbs.
Old Feb 5, 2025 | 02:54 PM
JohnLane's Avatar
222 S-65
OP did you fit a new radiator?
