Help with serious engine vibration at idle; 1984 500SEL
Misfires.... Can be fuel, ignition, vacuum leaks (false air) or mechanical.
It is plenty old enough to be having issues with any of the above.
You’ve not seen issues with K-Jet?
Start with fuel syestem check :
1 replace the fuel filter.
2 "there is a fine mesh filter in the delivery pipe end at fuel distributer, likely that is clogged from the symptoms you have mentioned including a normal start.
proceed on from more fuel pressure check and volume,
