Free 1991 420SEL
Free 1991 420SEL
I am not sure whether I should be happy or I am in for a major headache. I got this car free from a co-worker who does not want to spend anymore money on this car.
It is a 1991 420SEL with 171K miles. To date, he'd replaced the computer (4yrs ago) , rebuilt transmission (6 months ago), AC (2yrs), Radiator (2mo), Tires (3mos), sunroof, o2 sensor, battery last month and ect. Also the car was repainted a little more than a year ago. He gets so sick of the car that he does not want to deal with it anymore after recent incident.
Here is the damage. From looking at the pictures, I guess the rail or the tensioner failed and cause the timing chain to get loose and broke a piece off the valve cover. I do not think the chain is broken because I tried to get it out but I could not. I have removed the engine but have not had the time to open it up to see the extent of the damage.
What can you tell just from looking at the pictures? Any educated guess is much appreciated. Am I better off rebuilding this engine? or just buy a used engine?
Thanks in advance.
Thanks in advance.
89 420 SEL and 97 E320
Ouch
Mine did that a year ago... sorry man.
The plastic rails didn't get replaced on schedule (100,000) and failed, letting the timing chain jump off track and break through the left valve colver.
Your valves are shot. If you have a good/honest mercedes mechanic nearby, he can put new heads on it and you'll be good for another 250,000 as long as the oil is/has been changed regularly. The bottom end does NOT need to be rebuilt.
It ended up costing me about $3,500 total.
Sorry for the bad news.
1989 560SEL, 1999 S600, 2005 S600, 2008 S550 4Matic
Actually the plastic rails have no scheduled replacement. In fact, the M-B manual says ABSOLUTELY NOTHING about timing chain / rails replacement. The reason for this? Well, if oil changes had been performed religiously on schedule, the timing chain shouldn't break before the top end of the engine would require work.
Finding a used engine would obviously be the best for you, not to mention, cheaper than rebuilding that one. You can get a used engine with relatively low miles, change the timing chain and be set to go. However such an engine could be difficult to find.
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
Solution: Give it to me for free! My 16 year old would love to fix this one. He helps out on my Benzes. How 'bout it?
And actually, the chain will have to be replaced but it's not broken.
These are lessons learned the hard way.
Originally Posted by SL BRABUS
Now here come the hard part. ....Try to find someone who can fix it for FREE...... :p ..
Wow, I would have jumped on that deal myself. Congratulations! It's a great opportunity to learn too... you should work on it yourself, ask him "what comes off next" and get it all disassembled so that you can get the valves and everything redone.
By the way, I purchased a used valve cover for an excellent price at Potomac - IIRC it was about $40.
Actually, I am doing all the work (disassemble) myself and asking him when I need to. Like you said, it's a great opportunity to learn. I will probably ask him to involve more when assembling the engine back together.
I will post more pic when I get the heads and the timing chain cover off and hopefully not too much damage is done. I have already seen pieces of the guide rails.
1983 380se and 1981 280 ce
Please, please document everything and take photos. I will be doing the chain replacement, guide rails, tensioner, etc on my 380 sometime soon. The car has 135000 kilometers and I Know it should be done before 160000k's. This is going to be a challange but I know many have done the job themselves.
Originally Posted by Messerchmidt
Sell that thing to the bone yard
old mercedes when they give problems becomes black holes eating your money
While you are correct on that, to some extent, even all the advice you can get on this website won't necessarily save you on expensive to replace parts and labor-intensive operations that even the most hardcore DIYer would rather not do.
However I am not recommending you sell the car to the junk yard as of yet. It is up to you to determine how much money + time you have and are willing to dig into that beast.
Good luck,
Richard
Good luck,
Richard
Originally Posted by golfboy
hmmm... then 3 Mercedes mechanics lied to me!
Here's a better one: my friend's family has an '81 Toyota Diesel pickup truck. It currently has over 600K miles on it (odometer rolled over more times than they can remember and now doesn't work). Truck has rust all over it. Its timing chain has never been replaced. My friend's dad is strict about oil changes though: he performs his every 2,000 miles no matter what!!
Hey, those mechanics have surely made a lot of money by convincing the ignorant that timing chains should be changed every 100,000 miles. Just like they did with promoting 3,000 mile oil changes. Actually, I even had a mechanic tell me that my diesel's fuel injectors need replacement every 100,000 miles. Well, I know of a diesel with 322K miles running on the original injectors. And when tested, they came out almost as good as new, without sufficient deterioration to warrant replacements. You have to do your own research as those mechanics are all in it for money!!
Good luck,
Richard
Good luck,
Richard
The heads and timing chain cover should be out of the way by Sunday for me to assess the extent of the damage. By then I should know whether to junk it or fix it. Crossing my fingers
