S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
what does RS dash warning light mean??
Old 01-11-2005, 10:50 PM
dream7's Avatar
500SEC
Greetings to all MB friends from suNNy Florida!!
Just this evening on my 1985 500SEC, an RS (RED SQUARE) warning light came on the lower right side of the dash next to the ABS orange light and has not gone off.
Does anyone know what this means?
I searched my owners manual and not listed.
undefined
Old 01-16-2005, 11:52 AM
Jer
Jer's Avatar
1994 E320
This is a fault lamp for the Restraint System, a precursor to SRS. The RS only has seat belt tensioners. You should have the fault codes read at the dealership or independent shop with the special airbag test box.
Old 01-16-2005, 03:41 PM
dream7's Avatar
500SEC
Thank you so much!!
I'll take care of this week!
Old 01-16-2005, 05:19 PM
braverichard's Avatar
1989 560SEL, 1999 S600, 2005 S600, 2008 S550 4Matic
Your '85 500SEC must be Euro Spec...
I had that light on in my '84 Euro 500SEL, but after I pulled the instrument cluster to rebuild the dash rheostat, the light disappeared!
Old 01-18-2005, 01:15 PM
meowy84's Avatar
Braverichard, I have an '84 500SEL and have the light too. Any idea if that means it's an Euro model? There's a recent thread on here in trying to tell the differences between U.S. and Euro but there doesn't seem to be a consensus on what to look for to differentiate either.
Old 01-18-2005, 03:02 PM
I just posted a response to that thread and indeed, the VIN does tell us something... go and read that thread again for my response.
Otherwise, if your '84 500SEL has that light then it is probably a Euro Spec car, as the US Spec cars had the SRS light instead. I'm not very sure of this as I base my assumption on an '85 US Spec 500SEL, but since your '85 500SEC has the RS instead of SRS light, my assumption makes sense.
Old 04-10-2006, 05:33 PM
dwaycar's Avatar
Originally Posted by dream7
Thank you so much!!
Hello dream7,
Did you find out what made your RS light stay on?
Dwayne
Quick Reply: what does RS dash warning light mean??
