S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
84 300 D turbo runs after key is shut off
Old Jan 30, 2005 | 10:28 PM
Dog_Legg's Avatar
1984 300D turbodiesel, 07 c230
Question 84 300 D turbo runs after key is shut off
I have a 84 300d with 256,000 on it. I replaced the Transmission vacuum valve lever and now the car will not shut off with the key. The key shut it off fine before the replacement. What should be my first thing to check to see how to fix it?
Old Jan 31, 2005 | 07:30 PM
VonDeutchMB's Avatar
2005 C55 AMG, 81 500SEL AMG 6.0 (only 100k kms on the clock) 83 300d (wifes car)
1st chase all of your vacume lines that you touched.
2nd make sure the vacume valve lever is installed correctly. (I am asuming this is the one on top of the valve cover)
3rd make sure the vacume line atached to the ignition switch is still atached
That is all I can think of.
Old Jan 31, 2005 | 07:53 PM
moa4r's Avatar
S4
hello...I had the exact same problem with my 84 300D after doing some work in the engine...it turned out I had disconnected the iginition wire by mistake...I don't remember exactly where it was to be honest, but once I reconnected everything went back to normal...
Old Feb 1, 2005 | 10:40 PM
Dog_Legg's Avatar
I found the problem. A vacum line was plugged and needed to be cleaned out. Thank you for all of your input, it got me on the right path. Glad to have this forum to ask questions.
