S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Grilles for Mercedes
Old Feb 20, 2005 | 07:53 PM
mbenz85's Avatar
1985 European Mercedes Benz 380 SEL
Grey market info?
Hello everyone,
I drive a 1985 Mercedes Benz 380 SEL. I believe it is a grey market car. Does anyone knwo the specs for engine (or know where i could find them?)
I am also interested in finding a chrome grille for it. Share any knowledge you have. Thank you Derek
Old Feb 24, 2005 | 02:08 PM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
Most online parts sites can get you a chrome grill.
Fastlane for example at MercedesShop.com
But the aftermarket chrome isn't as good as the oe, the dealer can get the whole assembly for about $350 last I checked.
Also the dealer could run the vin and tell you if it is a euro car.
I think the vin on a euro car start with WDB126...
Old Feb 25, 2005 | 02:19 PM
OSCARSPAIN's Avatar
I´ve got a 81 380SE W126 EURO. You can see this page:
[B]
My car has this serial number: ABE NR B555
WDB 12603212012921
I´m sorry, my English is not very good.
The especifications are the following (It is in Spanish):
380SEL
Producción: Octubre de 1979 a Septiembre de 1985.
Nº de ejemplares construidos: 27.014
Motor: M116, 8 cilindros en V.
Diámetro/Carrera: 92x71,8 mm., a partir de 1981 88x78,9 mm.
Cilindrada: 3.818 cc, a partir de 1981 3.839 cc.
Relación de compresión: 9:1, a partir de 1981 9,4:1.
Alimentación: Inyección mecánica Bosch.
Potencia: 218 CV DIN a 5.500 rpm., a partir de 1981 204 CV DIN a 5.250 rpm.
Par Máximo: 31 mkg a 4.000 rpm., a partir de 1981 32 mkg a 3.250 rpm.
Transmisión: Cambio automático standard de 4 velocidades: 1ª-3,68:1, 2ª-2,41:1, 3ª-1,44:1, 4ª-1,00:1, MA-5,48:1.
Grupo cónico: 3,27:1.
Suspensión: Independiente a las 4 ruedas, delantera con trapecios transversales, muelles, amortiguadores y estabilizadora, trasera con brazos oscilantes multiples y diagonales, amortiguadores y estabilizadora. Opcionalmente control autonivelante hidroneumático.
Dirección: Servo asistida de recirculación de bolas. Diámetro de giro 12,26 m.
Frenos: Circuito hidráulico doble servoasistido. Discos a las 4 ruedas y ventilados los delanteros. Opcionalmente ABS.
Neumáticos: 205/70 VR 14.
Dimensiones: Largo 5,135 m., Ancho 1,820 m., Alto 1,440 m. Batalla 3,075 m., Peso 1.615 Kgr.
Velocidad Máxima: 215 Km/h.
Aceleración: 8,9 Seg. 0/100 Km/h.
Consumo: 13,3 litros/100 Km., automático 11,7 litros/100 Km.
Tanque de combustible: 90 litros.
