S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Starting, vacuum and automatic locks
Old Oct 7, 2005 | 12:27 PM
Gman91932's Avatar
1995 S320 and 1995 S500
Recently I starting having problems with my 1995 S320. First the vacuum on the door and the locks did not work when shutting the door or locking the car with the key. I searched and found the number 7 fuse was no good in the trunk set of fuse box. The the car started to not starting intermittently. I would turn the key and nothing. At the same time the vacuum and locks started to NOT work again. I tried to jump it this morning. That did not work. I waited 1/2 hour then the car miraculously started. I went straight to the mechanic and he could not tell me if it was the starter.
Does anyone have a clue where to troubleshoot this problem?
Gman
now no vacuum, auto locks not working and intermttient starting
