S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
500 coupe dies
Old Apr 5, 2006 | 11:56 AM
merandad's Avatar
500 coupe dies
I am a new member and I need help. My 96 coupe dies as I am driving the car, no advance warning, no warning lits no nothing. So far, I have been able start it go. I have showed it to a few mechanics and replacement of MAF or the CPS ( the sensor calls somthing else in this car). Recently a mechanic told me the 500 coupes have this problem mainly due to wear and tear of the wires around the engine. They have seen the wires covers to break away and rubbing of the wire causing this engin failure to happen. Has anyone experinces this? Any advice? I Thank in advance.
Old Apr 5, 2006 | 03:51 PM
brett san diego's Avatar
1997 S600 Sedan
Yes, look at your wires instead of typing on the computer. If they look like this, you have a problem:
http://v12uberalles.com/MAF_rewire.htm
and
http://v12uberalles.com/throttle_actuator_rewire.htm
I thought that the insulation on the wiring was a problem only through the 1995 cars. Maybe that is incorrect. But, you just have to look at the wires in your engine compartment to know.
CPS? Do you mean flywheel position sensor? This could be the problem.
Brett
Old Apr 5, 2006 | 05:29 PM
merandad's Avatar
500 coupe dies
Thanks for the comprehensive info.Mine is not a V12 but I'll start looking for defects. and yes, one mechanic recommended replacing the Flywheel Positioning Sensor.
Old Apr 5, 2006 | 06:08 PM
mbcrazy's Avatar
1998 s320 is mine.Wife drives 2002 c32
its not maf.i have that problem now.uneven idling,poor acceleration between 10-25 mph are maf related.
Old May 15, 2006 | 02:20 PM
merandad's Avatar
I checked all wires and they were fine. I took the car back to MB dealer and reminded them the signs I am getting may not be signs of bad MAF unit. Guess what, it was and it cost me over $700.
Old May 15, 2006 | 05:07 PM
NZ_Benz's Avatar
1993 300SEL/S320
Ok, what?
