S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
$100 light bulb ?
Old May 14, 2006 | 11:50 PM
merandad's Avatar
$100 light bulb ?
a week ago, My 96 S500 was in a MB shop for service. I asked one of the light bulbs behind the instrument panel to be replaced. the estimate $100. The bulb is a few dollars but the labor to take the cluster out takes over an hour. brought the car home and hoping I can save about a $100. Need help to pull the cluster out. is there a safe way to do it? thanks in advance.
Old May 15, 2006 | 01:59 AM
BenzKid24's Avatar
a Few Nice cars.
you need to buy the tools to do it or you will break them,its VERY easy to crack the cluster plastic so you need to be VERY CAREFUL,I dont know where to get them other then maybe try MERCEDESSHOP.COM
good luck~!
Old May 15, 2006 | 02:00 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
The cluster is a friction mount, you need to buy or make two hooks and follow the directions here:
http://www.mercedesshop.com/Wikka/W124InstCluster
Here is an eBay auction for the MB hooks:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4631130413
These are typically about $25 + shipping.
Old May 15, 2006 | 02:20 PM
vinamg's Avatar
If you're not comfortable doing it yourself you should try taking it to another shop. This is a 10 minute job. It should not cost $100.
Old May 15, 2006 | 02:31 PM
Vic_E55_2001's Avatar
E55 2001, Hayabusa 2005, TL1000R 2001
any two hooks will work just fine. it`s 3 minute job and cluster will pop right out. you can buy hooks at any autoports store or sears.
Old May 15, 2006 | 05:09 PM
NZ_Benz's Avatar
1993 300SEL/S320
My cluster plastic is cracked by what looks like someone who has been in at the cluster. It seems that I can only buy the entire cluster unit, I assume I can buy a new bit of clear plastic, anyone know what it costs?
