S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
something sparked and now I have no power steering???? H E L P
Old Feb 16, 2008 | 12:01 PM
llcelebrity's Avatar
1993 Mercedes 300SE
I was trying to fix some issues I was having with my shifter that I posted earlier and playing with a electrical switch by the shifter housing something sparked and now I have not much power steering....any suggestions...I tryed all the fuses in the trunk and under the hood..I guess that is the only spots for fuses are there any other....what did I do guys
Old Feb 16, 2008 | 10:21 PM
Z06EATER's Avatar
1997 C36AMG
i think there are some fuses on the
driver's side door by the parking brake release. check those also, just reset the computer by the unplugging the battery, if nothing then check to make sure there is fluid in the reservoir, and make sure all the plugs are in.
good luck
Old Feb 18, 2008 | 04:08 PM
1993 Mercedes 300SE
Does the car have a electronic assist for the power steering or anything like that
Old Feb 19, 2008 | 04:30 AM
carson357's Avatar
2005 C-230 Sport Sedan
check the fuses on the base module, it is located in the module box under the engine hood on the passenger side below the windshield area, there are red 10amp fuses there, you likely popped one.
Old Feb 19, 2008 | 04:31 AM
carson357's Avatar
yes it does
Old Feb 20, 2008 | 07:55 PM
1993 Mercedes 300SE
No Fuses Blown Whats Next???????????????????????????
Old Feb 20, 2008 | 09:39 PM
carson357's Avatar
and you are certain you checked the ones i mentioned above? there are 4 red ones under the little cover?
pull each one and check it out, where did the spark occur?
Old Feb 20, 2008 | 11:09 PM
1993 Mercedes 300SE
There is a box of fuses DRIVER side under the hood next to the front glass.......checked those nothing blown......the spark happened at the gear shifter...I had it all taken apart......the trans seems to be slipping a lil now to this all happened right after the spark.....I have messed something up bad im afraid....I have not taken power off of the battery yet to reset the system as requested by another thread....what now......also the two wires at the gear shifter that sparked (transpher switch from 4th to D) are dead nothing happens now when I touch them together so its sound like a fuse but its not HELP
Old Feb 21, 2008 | 04:06 PM
NZ_Benz's Avatar
1993 300SEL/S320
There are two fuse boxes under the bonnet one on the right one on the left. My car is right hand drive so it may be different for yours but the box on the RHS looking into the engine bay from the front is the main one, on the LHS there is the ECU fuses which can some times blow they are in a little black box and you have to take some screws out to get at them.
Old Feb 22, 2008 | 01:56 AM
1993 Mercedes 300SE
Ok ya I think i know where that is now I will try that and keep you posted
Old Feb 25, 2008 | 12:46 AM
1993 Mercedes 300SE
Dude That Was Exactly It Thanks So Much I Would Have Never Found Those Fuses!!!!!!!!!
Old Feb 25, 2008 | 04:39 AM
carson357's Avatar
are they the same ones i mentioned above? you said you had checked them earlier, were you mistaken or just not finding them? i tried to post a picture, but could not find a good one,
Old Feb 25, 2008 | 03:04 PM
NZ_Benz's Avatar
1993 300SEL/S320
Yeah they are the ones you mentioned, just not alot of detail on where to find them. I had to replace them some time ago and I found them really hard to find at first.
