S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1993 300se won't start
Old May 26, 2008 | 10:53 PM
jhholl's Avatar
I have a 93 300se. The engine turns over but won't start. It has become gradually longer to start, now it doesn't at all. Ive changed fuel filter, fuel pressure regulator, distributor cap and rotor. I didn't see a spark when I did an inline spark tester. I smell no gas. It doesn't even sputter when I spray starter fluid in it. New wire harness 1 year old. Any ideas ?
Old May 27, 2008 | 12:57 AM
Z06EATER's Avatar
1997 C36AMG
hmm would
it be the CPS? crank positioning sensor? get it checked.
Old May 27, 2008 | 01:07 AM
NZ_Benz's Avatar
1993 300SEL/S320
How are the spark plugs? Whats the condition of the battery?
Old May 27, 2008 | 11:51 AM
jhholl's Avatar
The battery is bad. I have to jump it to get it to get the engine to crank but it doesn't hold a charge for long. I also used a good battery testing it and the same result.
Not sure on the condition of the plugs. The car ran very smooth when it did start so I didn't think that was the issue. My concern is that i don't even smell gas. Would the crank position sensor be responsible for both no spark and no gas ?
Old May 27, 2008 | 04:59 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
You should heat the fuel pump(s) running when they key is turned on, they are controlled by a relay, but will only run to pressurize the system if it does not start.
Old May 27, 2008 | 05:01 PM
You should heat the fuel pump(s) running when they key is turned on, they are controlled by a relay, but will only run to pressurize the system if it does not start. I would also think CPS, with ether or gas and spark it should o something
Old May 28, 2008 | 04:32 PM
jhholl's Avatar
Agreed. That makes sense. I'll give it a whirl and let you all know what happens. Thanks again.
Old May 28, 2008 | 05:02 PM
jhholl's Avatar
300se won't start
One more thing... Is it the CRANKshaft sensor or CAMshaft sensor that could be the problem? Any idea what the difference is, besides the price ?
Old May 28, 2008 | 11:17 PM
jhholl's Avatar
GUESS WHAT...SHE STARTED !!!!
Well after 6 months of guesswork and buying parts I don't need my problem is SOLVED. All i needed was a new IGNITION COIL !
Went to see Sam at Advanced Auto Sports in Farmington Hills, MI. He was highly recommended by others and figured this thing out in no time. It's good to find a fair mechanic thats really looks out. Can't say enough about how much I appreciated that and getting back on the road. Time to get her all cleaned up. I'm back in the game. YEAH !!!!
Thanks for all your advise too. I helped to understand the cause and effect of it all. Much appreciated. GO TEAM !!!
Old Jun 10, 2008 | 11:09 AM
my_galaxy's Avatar
94 mercedes s320
94 s320 rpm goes up and down when hot
hi guys
i have a 94 s320, when i start in the morning it starts fine but when i drive around and stop on the light or just put it in the parking, engine's rpm start going up and down and sometimes it shuts down. but if i keep my foot on the accelerator just little bit then rpm stays normal.
can anyone help please?
thanks
Old Jun 10, 2008 | 11:10 AM
my_galaxy's Avatar
94 mercedes s320
oops
sorry put the post at the wrong place
