S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Power locks failure
Old Oct 25, 2009 | 03:30 PM
ironchef gop's Avatar
1996 S320
Power locks failure
Hello, new to teh site.
have a 96 320S.
Power locks don't work, including gas cap.
Was told it may be the vacuum under the rear seat. Wondering
1.. Is that accurate
2. What is fair price for part
3. Can I install myself.
Old Oct 25, 2009 | 04:21 PM
huffy's Avatar
1992 400se
Hello, I had that problem my vacuum pump was under the back seat(passenger side) very ez to replace not sure on the cost my pump was about $300.00
good luck
Old Oct 25, 2009 | 05:07 PM
1996 S320
Thanks for the heads up, was quoted a used one for 250
Old Oct 25, 2009 | 05:48 PM
1996 S320
huffy, where exactly would I see the part number. Also, any major electric or just plug and play
Old Oct 25, 2009 | 07:14 PM
huffy's Avatar
1992 400se
I had the dealer tell me the part # just plug and play maybe a strap or one bolt don't remember ez job
Old Oct 25, 2009 | 08:52 PM
1996 S320
Is there a resource on the web to get the part piece?
Old Oct 26, 2009 | 10:23 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
There are two versions of the pump, the earlier had aq plenum that all the hoses attached to and was plugged on the pump. the later used some 2 and 6 port "ts" and fittings. The pump is in a foam enclosure under the rear passenger seat
File Type: pdf
Old Oct 26, 2009 | 10:34 AM
1996 S320
If I took a photo and posted it, would you be able to help me idetify it. I pull up the seat and see where it is located. Also do I just glue the foam back on?
Old Nov 14, 2009 | 08:10 PM
1996 S320
I have a guy telling me his part
"95 S320.In excellent working condition.Bosch part# 0 132 006 350,same as 140 800 31 48"
will work in my 96 S320
Is this true?
