S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
s320 antenna
Old Dec 28, 2010 | 01:01 PM
walnutgroveplay's Avatar
1997 s320
s320 antenna
Just purchased 1997 s320 with telephone option. When car starts antenna goes up whether radio is on or off. What has to be done for antenna to be in down position when car is running?
Old Dec 28, 2010 | 03:27 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
You need to turn off the phone or disconnect the wire from it going to the antenna, pull fuse from phone.
Old Dec 28, 2010 | 03:29 PM
1997 s320
Thanks. We will give it a try.
Old Dec 28, 2010 | 04:04 PM
z168's Avatar
3phase-4pole
might be helpful to you
I hardly use the radio and play mostly CDs. So after I replaced the gear and belt mechanism on my antenna, i installed a wireless cut off switch. That way the antenna only goes up when I need it and prevent unnecessary wear on the components. I used a wireless switch so I dont have to pry every panel to snake a wire to the dashboard. works like a charm and is only $20.
Old Dec 28, 2010 | 04:15 PM
1997 s320
Where would one purchase such a switch?
Old Dec 29, 2010 | 12:34 AM
z168's Avatar
3phase-4pole
Ebay. Look for it as "12V wireless switch" or "remote"
Old Dec 29, 2010 | 10:04 AM
1997 s320
Thanks for the info
Old Dec 31, 2010 | 12:27 PM
The later models have the AM in the glass and FM in the bumper you might not need it.
