92 400se gas odor
when you take off your gas cap do you hear a vacuum or pressure release?
there is a small plastic valve on the bottom of the tank called a Regeneration valve that releases pressure to vent fumes thru a charcoal filter which is locate under the front left wheel well.
I had problems with this regeneration valve which did not release and caused tank to collapse but I noticed fumes before the collapse. But the first thing I would check is eithe rvacuum or pressure at gas cap removal.
kind of an internet works for car parts
they have been doing this for a long time
