S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S320 performance modifications
Old Jun 19, 2003 | 01:49 PM
Bernanke's Avatar
Question S320 performance modifications
hey guys, I'm new to the MB world and I came across a few mods and I was wondering what yall though.
Chip -- speedtuningusa.com has chips for my car for only $250 which is very reasonable in my opinion. 21HP and 25Nm torque is what they claim. Jet Chip charges $400 and they claim about 16-18 wheel HP with 10% increase in torque. Which do you think is the best of the two? have any of you chipped your W140, if so what were the results.
Intake -- I plan to make my own custom intake b/c it will save a ton of money and plus its pretty easy to make a heatsheild. How much should intake help on a 1993 S320?
Exhaust -- Is this even a worth while mod on W140's (especially a 6 cylinder)? What about straight pipes?
How is the OBD1 vs OBD2 modding on benzes? do pre 1996 cars get alot more HP per mod than 1996+ cars?
Also Some chips offer a raised rev limiter, what is a safe amount to increase the rev limiter by on the S320 motors? 200rpm? 400rpm? anyways guys, thanks for your help guys
Old Jun 20, 2003 | 09:35 PM
Bernanke's Avatar
anybody??
Old Jun 22, 2003 | 12:11 PM
shmelvin's Avatar
none
Just sell it and get the 8 or 12 cylider
I have tried all the tricks, but trying to make a car something it's not always leads to trouble. Let's face it the 300 series are all show and no go. (I don't agree with it) but you can always re-badge and then it will feel a lot more powerful...LOL
Old Jun 22, 2003 | 01:44 PM
///S320's Avatar
S320W
Re: Just sell it and get the 8 or 12 cylider
People coming from American car mentality keep putting down the inline 6 engine of the S320 as if it was built by Pontiac.
I think my car runs, and runs quite fast. Its not a V8 or 12, but its enough to move a car of this size very efficiently. Thats engineering.
Old Jun 22, 2003 | 01:56 PM
shmelvin's Avatar
none
You are correct
///320 You are correct, but omey doesn't want efficiency...he wants power and he will have to strain that engine to match the 8 or 12. Your 6 is an excellent engine and manages to push these barges around quite well. On the other hand I was cruising at 140mph down I-79 yesterday at just over 3000 revs, that aint going to happen with a 6.
Old Jun 22, 2003 | 08:28 PM
Bernanke's Avatar
Re: You are correct
well i technically have a 300SE which has the 3.59 differential is just as fast as the 400SE was, so its not slow. Car feels very peppy for a inline 6 pushing 4200-4400 lbs (whatever the actual weight is of inline 6 SWB W140 ). I think chip and intake will suffice, I don't want drag car performance I just want something livably fast b/c I'm coming from a BMW M3 so i need something that will at least partially crave my thirst for speed .... somewhat. Anyways any help would be appreciated. thanks guys
Old Jun 29, 2003 | 06:38 PM
Bernanke's Avatar
bump
Old Jul 3, 2003 | 02:01 PM
possessed007's Avatar
Mercedes S320w 1995
Originally posted by OmeyHomey
bump
hey there I'm looking for an S320 air intake as well what have you found? Cause since my air filter housing is broken a new one is like 300.00$US I would rather spent it on an Cold air intake.
Old Jul 3, 2003 | 04:50 PM
Bernanke's Avatar
ya just go the custom route, make one yourself, its alot easier and you will get more HP than any company could make, just get the right diameter K&N cone filter with the necessary tubing and a heat sheild and bingo, its that simple.
Old Jul 3, 2003 | 08:58 PM
Mercedes S320w 1995
Did you do it already I would like it if possible to send me some pics of your setup did you have any problems with the sensors?
Old Jul 3, 2003 | 09:23 PM
Bernanke's Avatar
I did not do it yet but I can explain how to do it, its very easy on the car especially since the engine bay is so open (engine bay is designed for v12 to fit so I6 leaves plenty of room). Get K&N filter (check opening diameter of the HFM, its either 3.0 inch or 3.5 inch) for the right opening. next get some aluminum sheet metal (like $5 for 3 square feet) from either Lowes or HomeDepot. bend it how you like, cut hole (3 inches diameter or 3.5 inch according to the right size needed), then spray paint it black and put felt (cotton fuzzy cloth) on the engine side to act as an insulator. Bingo Cold air intake, companies do this for BMWS and charge $150-350 for something so simple. I was going to do it but now it seems like I may be getting a porsche instead
Old Jul 3, 2003 | 09:34 PM
Mercedes S320w 1995
yeah but will my OBD or the mass air sensor freak out?
Old Jul 4, 2003 | 12:38 AM
Bernanke's Avatar
no, especially if its OBD1, if its OBD2 you should be ok too as well b/c BMW M3's are both OBD1 and two and the intakes are the same. hope that helps
Old Aug 3, 2003 | 04:22 AM
Bernanke's Avatar
just to keep yall updated I will be developing a cold air ram air intake kit for my 300SE. it should work with most 6cyl benz motors, it will be carbon fiber (most probably fake) and i should be able to make the kits for $50-100, MUCH better than the unbelievably bogus prices people have listed.
does anyone have the transmission gearing information for the 4speed and 5 speed, along with the differential gearing for 300SE and S320 respectively? I REALLY need to know this.
I will keep yall updated on the intake
