Mercedes w140 dashboard light fail :s
i just bought a 1995 w140 s320 with 130 000 km ,
I noticed once i bought it that when i turned the lights on nothing on the dashboard lights up (buttons , instrument cluster and central console):s .the only thing that lights up is the odometer , i knkw about the dimmer switch and when i turn it it only brightness the odometar nothing else. And every fuse seems ok :s
So pls can some one give me advice ???
Kind regards
Kind regards
Is that also true of wiring within the dash area?
Some of my dash bulbs clearly are burned out, and the bulbs which (I think) illuminate the HVAC digital temps and temp wheels are also out, except the driver-side bulb rarely comes on, then "goes on vacation for a long time." Wiring?
James
P.S. It's really frustrating when at night you can't see where your temp wheel is set.
You also could have a bulb out or a loose connection.
James
P.S. Question about going through the left-side speaker vent: that gets you to the left side of the cluster, but what happens when the right side "sticks" and you can't move it?
