Power assisted trunk latch / door failure
Have got a 95' S500 Coupe. Apparently the pneumatic, power assist in both the doors and trunk failed. Trunk lid locks but does not close flush with the cars body. I do however have air pressure to inflate the lumbar support in the seats however.
A fuse maybe? Any ideas?
Inside the trunk on the right hand side. There is a fuse box. Remove fuse #3,6,9,11. Then wait for 30 seconds. Then put them back on.
Please tell me if it works. I have tried several times and it worked.
Good luck
You can try this trick:
Good luck
I hope I won't have to do this every week. But if I do, pulling 1 fuse is better than 4 !
I just am wondering what the root cause of the problem is.
Electrolytic capacitor are known to go bad over time.... I wonder if that is the real culprit here.
I am forceful.....on the doors. I would not call it slamming.
Before this happened, the trunk lid was not catching all the time and I would have to use alot more force than I normally use to engage the latch. I attributed it to a minor mechanical missalignment on the latch. In the past, it took almost no pressure at to close the trunk. My wife is gulity of always slamming the trunk and I told her not too... BUT now even I have to!
Now that the power assist is working again I still have to forcefully close the trunk a FEW TIMES before the latch engages.
Think its time to get a 1999 CL500
I guess I can:
1) Get a new pump
2) put a relay / timer in line with the #9 fuse
3) disect my pump
4) ?????
Is there a 4th option ??
compuserve.com I believe his firm can rebuild your unit.
He is very reputable. He is also technical director of the
Star magazine. My instrument cluster and central locking
pump is at his facility right now, being rebuilt.
