S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Modification Epiphany (light bulb)
Old Aug 3, 2003 | 06:11 AM
Bernanke's Avatar
Lightbulb Modification Epiphany (light bulb)
hey guys, ok bear with me...
W140 6cyl up to 1995 had the 4 speed auto (essentially 3 gears plus 1 overdrive). i do not know the ratios but i would REALLY REALLY like to know. I do know however it has 3.58 or 3.59 differential gearing (i forget which but close enough either way).
The 5 speed "speed adaptive" W140 transmission is the same for all the motors on the W140 chassis (v6-v12) and the ratios are all the same. essentially its 4 gear + 1 overdrive. Not only that but its much lighter than the old 4 speed and uses 40% less parts ( which means more reliable).
if the gear ratios work out properly that means the 300SE i have could have 5 speed PLUS the 3.59 differential there by making me have 1 extra (much more aggressive) first gear there by helping out performance and acceleration alot.
what do yall think? good idea or what?
Old Aug 3, 2003 | 06:13 AM
Bernanke's Avatar
here are the ratios of the 5 speed (i believe) just for reference sake. I will check my 300SE manual tommorrow for my tranny ratios....
1st Gear: 3.93
2nd Gear: 2.41
3rd Gear: 1.49
4th Gear: 1
5th Gear: 0.83
Old Aug 3, 2003 | 05:43 PM
Bernanke's Avatar
i realized this might not be worth it after all, cuz most first gears are about the same on both 4-5 speed trannies. oh well, it was worth a shot
