S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Fuel pump
Old Sep 22, 2013 | 03:36 PM
BigBoyToyS420's Avatar
1997 Mersedes S420
Fuel pump
I have a 1997 mercedes s420 my fuel pump doesn't work when I jump it it comes on I checked the fuses is they are good is it a way to check if the relay is bad? Thanks!
Old Sep 23, 2013 | 04:51 AM
oldsinner111's Avatar
s320
you jumped fuel pump and worked,you just tested relay
Old Sep 25, 2013 | 06:24 PM
1997 Mersedes S420
I jumped it from the relay
Old Sep 26, 2013 | 03:12 AM
s320
what do you mean? Did you bypass relay,or open relay and hold points down
Relays are common to fail first. also to act up is the wires leading to pump,sometimes cleaning is needed.
