S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Transmission problems
Old Dec 18, 2013 | 06:20 PM
Philip317's Avatar
s320cdi /SL350/Slk 230
I would appreciate hearing from you out there who have had transmission problems. I'm gathering statistics on the topic and I would appreciate. Hearing from you. My email address is: philip@philiposullivan.com
Old May 5, 2014 | 10:15 PM
1992400se's Avatar
1992 400se
I have a 1992 400se, I had trans. rebuild last year , and the car does not change gear without raising engine, its shifts gear at 25mph and 65mph. Do you have any idea what it could be
Old May 20, 2014 | 09:09 PM
davescls's Avatar
cls550, s320, 300se,323ic
My 96 S320 with 140.000 miles had the tranny pulled 7 times and no one could fix it. 3 different shops and the last being the dealership. They ended up putting in one from the bone yard. It still isn't right. I skips 4th and goes right into OD. Moving the shifter back and forth has no effect.
FOR SALE
Old May 23, 2014 | 06:40 AM
oldsinner111's Avatar
s320
alot of transmission problems can be traced to ATF entering the computer box.Theres a plug that goes bad on the transmission and can wick oil into brain box
Old May 23, 2014 | 09:15 AM
davescls's Avatar
I read thousands of posts while I was having problems. Leaking ATF was the first thing we looked for.
Old May 23, 2014 | 10:19 AM
s320
maybe both units needed a conductor plate replaced.I don't understand the 722.605 trans is suppose to be good for 325,000 mile3s,as long as fluid is chaged.
Old Sep 12, 2014 | 12:56 PM
samiemalik's Avatar
81 300SD 92 300sd 94 E320 90 260e
Fix it right the first time
FOR SALE
When rebuiding a transmission, change out the B1 Band, Replace Gaskets, Modulator, bowden cable. Also check the kickdown switch and any vacuum leaks. Call Ted Reich Transmeister in Orange CA, 1714.532.1871. He is the Best in the business. $600 labor x 7, $4200 labor back and forth, wow thats nuts
Old Sep 16, 2014 | 02:28 PM
bavarianfanatic's Avatar
W140 S500, W220 S55, R107 450SL, E32 750il, E34 M5, F80 M3
I just did the conductor plate in my '97 S500. I was amazed at how clean the internals of the trans were and how little friction material was in the bottom of the pan. Seems to be a very solid trans. 157k on the clock by the way.
