S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Headrest Problems
Old Jan 2, 2004 | 02:16 PM
HeadTurning400E's Avatar
400E (177k)
Headrest Problems
Hello,
My dad's 500 has a problem with the headrests in the front, they worked perfectly up until a few days ago when nothing happened. When i press the button to make them go up i hear the motor working, but the headrests move not. Is there anything i can do short of taking it to my mechanic, or even worse, the dealer?
Any suggestions would be much appreciated.
Old Jan 2, 2004 | 08:10 PM
AREITU's Avatar
You'd have to take a look at the mechanism that raises and lowers the headrests. Maybe the ratchets are broken or something. I think my friend's 320SEL has the same problem.
Old Jan 16, 2004 | 01:15 PM
Raul J. Carrasq's Avatar
1994 S320
I had the same problem with my S320 1994. It is very simple to fix. Just take off the back panel of the seats and take a look at the mecanism. you will see that at the bottom of the supports of the support of the headrest there is an alongated whit and blue plastic part. That is probably what is wrong. Good luck.
Old Jan 19, 2004 | 11:12 AM
MBS420's Avatar
S420
Question
I have the same problem on my passanger's headrest. Can U show me how to take out the back panel of the seat !! Thanks in advance.
Old Jan 19, 2004 | 01:47 PM
1994 S320
There are two screws at the bottom part of the back panel of the seats, one on each end. Just take them off and release the panel. Good luck.
Old Jan 19, 2004 | 03:29 PM
400E (177k)
thanks, ill get to it hopefully tonight
Old Jan 19, 2004 | 04:05 PM
MBS420's Avatar
S420
Thumbs up
Thanks a lot for the information!!
Old Feb 3, 2004 | 04:45 PM
MBS420's Avatar
S420
Updated:
I opened my seat back and found out the plastic roller which roll up and down the headrest is broken. Just order parts from MBZ dealer (cost about $22.00), it is fairly easy job to replace it. The parts come with roller and rail together.
:p
Old Feb 3, 2004 | 07:53 PM
400E (177k)
awesome, thanks man, my stealer doesn't exactly have the most brilliant parts manager, could you send me the part number please?
Old Feb 4, 2004 | 11:49 AM
MBS420's Avatar
S420
When I purchased parts, the parts manager told me there are several different part number depending upon your VIN. My part # may be not useful for you. You have to look at your VIN and browse through parts diagram on their computer to specify the part you need. AS fas as I know, driver side is different from passanger side.
Good Luck.
Old Feb 5, 2004 | 01:04 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Hey, post the year, model and last six of your VIN and I will get you the number.
-D
Old Feb 5, 2004 | 11:15 PM
400E (177k)
94, S500, 163424
Old Feb 6, 2004 | 01:28 AM
dlafever's Avatar
Great! You need a 140 970 00 26, they are the same p/n for both seats and there is one per seat. Retail for the pair is around $40.
-D
Old Feb 6, 2004 | 06:47 AM
400E (177k)
Thanks, much appreciated!
