S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
ASR
Old Jan 4, 2004 | 07:25 PM
MB AMG's Avatar
2002 E55 AMG
ASR
Somebody told me if I hit the tire switch, it will turn off ASR until 25MPH/40km/h. I did that and when I florred it on wet pavement, the ASR light came on. It revved higher than before, but does it mean that it was completly switched off?
Is it normal for ASR to cut engine power off, because I felt that when it was activated?
Old Jan 4, 2004 | 07:37 PM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
It will cut the throttle if you're going fast enough with the switch on, and whenever its activating it will light up in the dash. Eventually I'll disable mine altogether, something to look in to!
Old Jan 9, 2004 | 07:55 PM
MB AMG's Avatar
2002 E55 AMG
Yeah, but I hit the switch and the ASR activation light still came on?
Old Jan 11, 2004 | 02:33 AM
markku's Avatar
S320L -97
ASR
It still acts as a limited slip reduction. Fortunately.
Old May 6, 2011 | 12:18 PM
mswann60's Avatar
C240, S500
Deleted by moderator
9 times out of 10, its a "noisy" connector or fatigued wire on the front axle. the $10K advice is to prepare you for the bath he plans on giving you because you are an attorney with deep pockets. Find a competent independent.
On my 98 S500, my ASR would go off after sitting overnight when its cold. I found the problem by wiggling the cable one corner at at time before start up. It was the right front connector.
