S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Trunk is not closing ?
Old Feb 26, 2004 | 05:44 PM
ghost's Avatar
1997 S600 - Bentley Turbo R (black/black)
Hello:
my car is been sitting in the my garage for the past 2 weeks. So when i went to start it today, the battery was dead. I jumped the battery, and i started the car, and doors closed fine. But the trunk is refusing to close, the soft close is not getting activated.
I tried to gently close it, but its not locking nor is the soft close kicking in.
Any help a.s.a.p would be appreciated?
Old Feb 26, 2004 | 06:33 PM
ghost's Avatar
I think i might have resolved the issue.
I tried taking the soft close, and central lock fuses, but that didnt help.
Then i figured out there is a switch in the inside of the trunk behind the outside closing button to close it manually, i moved it to the side, and the trunk closed with the soft close.
Old Mar 18, 2004 | 10:59 PM
Snowman's Avatar
Ghost,
I tried your solution and it worked wonderfully. I wonder if I just had the car the whole time like this. My only thing is that this might cause premature death of the closing assist pump.
Old Mar 18, 2004 | 11:43 PM
ghost's Avatar
snowman:
Yeah, i felt such relief, when this worked. Since my trunk wasnt closing at all, and also $$$ started flashing in my head, because of what i heard about fixing soft closing assembly.
But then again, at least in my case, the cause was the battery drained and reset everything, and i had to reset. I never had any problems with soft closing.
I dont think you will experience major problems with that. If you do, i have read, that you can take fuses in and out, when it happens, to avoid fixing it. lol
Old Mar 19, 2004 | 12:36 AM
Snowman's Avatar
LOL I swear these 140's have so many quirks. It's an adventure just owning one.
