S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
what oil brand /weight, and oil filter does everyone use
Old Mar 24, 2004 | 11:09 AM
98sclass's Avatar
i want to put in mobil 1 0w40 at the next oil change in my 1998 s420. is that a good weight to go with?
also how many quarts of oil do i need? and what oil filter does everyone use? oem?
Old Mar 24, 2004 | 11:48 AM
snik's Avatar
96 S500 Coupe
i buy my filter from the dealer... OEM stuff.. and use 20w50 valvoline or castrol gtx.. 5.0 engine takes 10 quarts... 4.2 should be similar, although consult your owner's manual to be sure
Old Mar 24, 2004 | 12:59 PM
99bmw740il's Avatar
2006 Mercedes E350 Sport
been running mobil 1 since the first day- 5w30... im skepticle of amsoil and other 10k mile interchange oils
Old Mar 25, 2004 | 02:15 PM
ychachad's Avatar
1995 S420
I use Shell Synthetic 5W-40. If it's good enough to go into a Ferrari, then it's good enough for my Benz. Benefit is Cost. I can get a gallon jug for 13 USD, versus about $18 for Castrol 5W-50, or Mobil 5W-30. I would choose any one of those.
Old Mar 28, 2004 | 03:45 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Castro synthetic 5W/50 here.
Old Mar 28, 2004 | 07:22 PM
Bernanke's Avatar
a synthetic 5W-30, or 10W-30 would be best. there is an actually difference between oil weights. a 10W-30 will allow the motor to rev more freely and the motor will seem peppier than with say a 20W-50. and since its synthetic, you don't have to worry about protection. It may not add up to actual extra HP on the dyno but it definately dose make a difference in terms of the characteristics of the motor.
Old Mar 28, 2004 | 08:05 PM
Adobe's Avatar
Mercedes does NOT recommend using 5W-30 or 10W-30 Mobil 1 anymore since the 30 weight Mobil 1 oils now use a petroleum base.
Look here and scan down.
http://www.whnet.com/4x4/oil.html
Use either 0W-40 or 15W-50 Mobil 1. This business about light weight oils providing better fuel economy is something that car manufacturers have been telling us to justify them recommending low viscosity oils to help them with their CAFE averages. In practice, you won't see much difference. There's no question that the heavier weight oils provide better viscosity under severe conditions than the lighter weight oils.
15W-50 Mobil 1 has the same pour point as a 10W-50 dino oil and about what the petroleum based 10W-30 Mobil 1 has now.
The 15W-50 Mobil 1 has more anti-wear additives than the 0W-40 which are supposed to be harder on catalytic converters but the amount of zinc in it isn't going to hurt the cats.
I've been using 15W-50 in my cars for a long time and have experienced no noticable oil consumption using it.
Old Mar 29, 2004 | 03:26 AM
Bernanke's Avatar
mobile 1 10w-30 is all the protection you need in the world. Mobile 1 is the most pure of all motor oils (redline is almost identical). I have seen numerous indepth oil tests and mobile 1 outperforms everything and has the highest flash points and etc. 10W-30 will do just fine.
Old Mar 29, 2004 | 08:41 AM
Adobe's Avatar
Read my post above! Follow the link I provided! The 30 weight Mobil 1 oils are no longer true synthetics and Mercedes no longer approves of them. In fact, they've told their dealers not to use them.
I agree that Mobil 1 should be used but not the 30 weight viscosities. Use either 0W-40 or 15W-50. These are true PAQ based synthetics.
The 30 weights are Base III oils made from petroleum bases.
And Redline is not *almost identical*. Redline is a Base V oil which can stand the temperatures of jet engines. The petroleum and PAQ based oils of Mobil 1 will not.
