S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Brake Problem
Old May 8, 2004 | 11:21 PM
lungta's Avatar
Brake Problem
I just changed the front and rear brake pads on my S420 year 98. I put new pads in and everything seemed to go fine. After putting everything back together, i tested it around the block and the first push on the brake pedal seemed to be fine. However, after the first one, the pedal seems to sink way down and i have to push it all the way down to stop the car. So i tried to bleed and the car. I did it 3 times and i still have the same problem. Does anybody have any clue what is wrong with my car. I hope it is not the brake master cylinder because my MB dealer quoted me $1300 for it when i called them today.
Old May 9, 2004 | 06:31 PM
snik's Avatar
96 S500 Coupe
its $850 not $1300
http://www.germanstar.net/140bp.htm
cant you just take it out and have it rebuilt?
