S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Immobilizer and Starting Issue - '99 S320
Old Jun 4, 2019 | 08:50 PM
mikeybbrooks's Avatar
2002 CL500, 2001 S500, 1997 S500, 2004 E320 and 2005 CLK320
Hello all! I have purchased a non-running 1999 S320 with 177k miles (don't hate, please) in a non-running condition. The owner said the immobilizer was the issue and I tend to agree because the prongs on the black connector were "wonky"
I went to the salvage yard, and got an ECU, immobilizer, and the key ring from the ignition switch that connects to the immobilizer... from another S320 (1997 I believe). I sent the immobilizer and key to get programmed so that they sync. The guy provided a new key that matches the immobilizer and cut it so that it works in the ignition and door locks.
I've put the ECU, immobilizer and key ring thing into the car, and I'm still getting the Start Error message. But what's now happening is the alarm is going off (flashing lights).
Any idea on what happened? Why won't the car now start? I really appreciate the help with this one. I'm trying to keep these old W140's on the road (I have an S500 that I love) but this one has me baffled.
Thanks!!
I've run a CarSoft 7.4 scan on the car and received the following error messages:
ME – 1570 - CAN between IFZ and ME control unit (Engine 120: right)
ABS / ASR – Airbag – SRS Malfunction Indicator Lamp (A1e15)
Voltage supply low, Terminal 15R
BAS - C1012 Battery : Tension to high at Terminal 87
C1025 CAN – Communication
C1332 BAS – Solenoid Valve
Cluster – B1040 CAN Communication error with the Engine Control Unit
B1042 CAN – Communication error with the BAS Control Unit
B1471 Temperature Sensor External Temperature (short circuit to ground)
B1755 Serial Port K2 from the KLA/TAU panel with the instrument cluster : open circuit
B1473 Coolant level control switch S41 or clean water level switch S42 – open circuit
EGS –
F97 – 105 Error in the Anla8sper relays wiring
F113 – 116 Anla8sperr contact (ASK) without function
Gear box oil temperature sensor – defective
Telefon:
136 – Communication with KOMBI Instrument disturbed
148 – Selector Level blocked / converter lockup clutch (KUB)
PSE – B002 Central Locking : air demand excessive
F242
F87
B016 – Interior switch : Signal > 2 min.
