S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 300SE EGR Valve Question
Old Oct 27, 2021 | 06:47 PM
Carl W. McCloud's Avatar
'08 S550; '92 300SE; '10 QX56 Infiniti; '16 Colorado;
Question 1992 300SE EGR Valve Question
The EGR valve in my 1992 300SE is bad. The OEM part number is 001 140 95 60 but is no longer being manufactured anywhere. The same part also fits the 88-93 300TE (and a number of other MB with the 104.99x engine). Online I found a EGR valve which looks identical (part # 000 140 41 60) that will fit the 1992 300TE but according to MB will not fit the 1992 300SE. How can part number 001 140 95 60 fit both the 300SE and 300TE but part number 000 140 41 60 only fits the 300TE and not the 300SE ? Thanks for any help with this before I make the leap and purchase 000 140 41 60 despite the possibility it won't fit.
Old Oct 29, 2021 | 08:11 PM
Originally Posted by Plutoe
you use MB EPC to answer your question----find a copy and look your self
Thank you. Very helpful resource but only points me back to the OEM part that is no longer available or being manufactured. I'll order the part that MB says won't fit and hope for the best. Will provide feedback afterwards. thanks again.
Old Nov 22, 2021 | 11:02 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
It is just a valve. If one of them works in both mods I assume that fittings are the same size so I would buy the one available and install it.
Old Nov 23, 2021 | 06:06 PM
I ordered part # 000 140 41 60 and only had to move the old fitting from the old valve to the new valve for it to fit my 300SE perfectly! Thanks for everyone's help.
