19' Wheels Problem
When driving on the freeway I have also noticed a "wind type" whistling noise. Could this be caused by the spokes of the Brabus Mono VI's? Has anybody else experienced this?
There have been a few occasions where the tires have rubbed. I live in So. CA were the roads are pretty bad. Its amazing how the most expensive areas have the worst roads and street lighting. But anyways one of our freeways is built on a landfill and has wave like dips in it. Everytime I pass over these dips around 65MPH the tire rubs. Is there anything that can be done about this?
I am running Michellin Pilot Sport PS2's 245/40ZR 19 in the front and 275/35ZR19 in the back. I was told that these are the best tires as far as minimal road noise is concerned.
Thanks for any help on this matter...
. Next time around I will give the Goodyear's a try, hopefully that won't be too soon.
Try toyo proxes tr1's they are very cheap but very good tire for around 600 bucks for your setup. I am running a set om my S500 now and they also have a very aggressive tread.. for a couple of more bucks you can run the NITTO 555's... all of the hype on the pilots and goodyear is not even close to being worth the ridiculous price. believe me.
Call my buddy Devin at the WheelWarehouse.com in the OC in SOCAL.714-772-1281 x5104. They have the best prices on tires and wheels.....truly
Thanks for the info and contact information. I will give the Nitto's a try next time I need new tires. Too bad I didn't know this before spending $1,500 on the pilots.
BTW nice car. Love those rims, what kind are they? Did you change the tail lights or is yours a 2003 +. Reason why I'm asking is because I want to change my '02 tail lights but all the ones on Ebay are aftermaket and I didn't know if there is a big difference in quality compared to OEM Mercedes lights.
IM not sure what to tell you, i have noticed that some 19" tires are worse than others on noise. Its more of a random noise than tire sound, at least it was when i went to 19's on a clk.
As far as the rub, some tires are a little bit taller or wider than others. I cant remember the correct size becuase i sold my car in 02, but for example lest say i had 245 /30/19 Good years up front. The car would only rub at speeds above 80 mph. So after getting a cut from the finder on the top of the side wall i went to 245/30/19 Nitto tire and the rub went a ways. When you get the lowered big tire combo going there will be problem every now and then
As for as the clanking noise i had that with my spacers as well. i would retighten the studs to double check that nothing has come loose. Also you might want to pull the tire off and put some white litheruim (sp) grease on the side of the spacer that goes to the car ( not the wheel) I found on mine after about a year they had rusted / stuck together and it was almost impossiable to get off. Not sure how the brabus set up is though.
The Michelin PS2's are worth the money, you can ask anyone in the AMG forums.
http://www.toyo.com/tires/tire_lines...sedan/tr1.html#
