Just installed updated taillights
Old Dec 5, 2005 | 02:16 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Just installed a set of updated taillights 2003 style.
Got it on ebay. $180 shipped.
Simple to install. but you will need a phillips screw driver, 8mm socket, and Torx bit to remove the LED array.
Here is a simple write up.
1. Pull trunk liner panel to gain access to the tail light.
2. unplug the black rectangular harness.
3. remove the 4 x 8mm nut.
4. carefully pop out the OEM taillight.
5. Transplant all the bulb & socket to new taillight.
6. Transplant the LED array panel.
a. remove OEM light LED array cover Torx screw
b. pop out array from the 2 electrical contact.
c. reinstall in new taillight in reverse order.
7. reinstall new taillight on car.
8. tighten the 4 bolts. DO NOT OVER TIGHTEN.
9. Plug in black harness
10. reinstall trunk liner.
Repeat to on the other side.
Should take about 10min a side.
Old Dec 5, 2005 | 07:30 PM
Incendiary's Avatar
2014 E350S4
Pics of before and after?
Old Dec 8, 2005 | 11:34 AM
fkong777's Avatar
Let me try to get some pics this weekend.
Didn't think I needed pics since the updated taillight is OEM looking.
BTW my take on the new taillight compare to old aesthetically.
Given that the four stripe light looks newer, I noticed...
It made the W220 looked wider and longer. In a good way of course.
I suppose the 4 horizontal stripes do something to the eyes.
Old Dec 8, 2005 | 12:44 PM
Rlo's Avatar
Rlo
I couldn't agree more!!
When I see an 2002 or earlier on the road or in a parking lot, compared to my updates '02, I say everytime my back end looks so much longer and wider, plus with the AMG apperance rear bumper, also more aggressive looking
Now for a quad exhaust, for a real mean look
Old Dec 8, 2005 | 05:27 PM
newton22's Avatar
BMW E39
I once tried taking off the tailight, not to replace or upgrade, but just clean out some debris inside.
I had the 3 nuts and bolts removed and the wire harness unplugged, but no matter how hard I budged, the tailight wouldn't come off. Any harder, and I was afraid I was gonna snap the assembly.
Old Dec 8, 2005 | 07:08 PM
fkong777's Avatar
there are 4 bolts to undo.
Old Dec 8, 2005 | 07:47 PM
newton22's Avatar
BMW E39
LOL, I'm an idiot. But where's the fourth one?
Old Dec 8, 2005 | 11:11 PM
koreanpers's Avatar
S500
thank god u did not keep pushing, u could have broken something If u look at the side of the tailight from the outside... the bolt connects on the side of it from the inside. You have to pull the carpet back a little bit further...u will see it.
I also updated my tails..and WOW, it makes a huge difference
Old Jan 10, 2007 | 08:10 AM
Mark_K's Avatar
2002 S430
I just recieved my tail lights.
I notice that the original poster said that you have to take the LEDs out of the old tail lights and but them in the new ones.
Mine come with LEDs already in them. the people that already did this, did your come with the LEDs already in them?
Old Jan 10, 2007 | 01:07 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Yes, mine did and if someone got them without they got jacked. Mark, there are 4 post screws on your new tail lights. you need to remove/unscrew 1 of them to install them ...there are 4 nuts on your your existing lights to be removed. .. when you yank the old ones out you will see what I mean.. you also with have to remove the bulb twist holders from your old lights and install them in the new ones..
Old Jan 10, 2007 | 01:42 PM
Mark_K's Avatar
2002 S430
Thanks for the reply.
What about the LED part? My new one comes with the LED lights in it I think or does it just look that way? I only looked at them real fast.
Old Jan 10, 2007 | 03:05 PM
ironcheflam's Avatar
S430
i got some pics of it if you cant wait for fkong
Old Jan 10, 2007 | 03:34 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I bought OE Mercedes from Performance Auto Parts several years ago; they had the LEDs in already. They also cost around $350. I have read that some (but not all) Asian products require transfer of the LED panels from the OE lights, but don't know which. Leaving the LEDs out probably helps get the price to the $180 mentioned. If you install taillights that don't have any LEDs, you'll get a warning of a burned out LED cluster (or bulb) on the instrument panel.
Old Jan 11, 2007 | 07:48 PM
02S430's Avatar
W220 M113K
are ur guys oem or aftermarket? i got mine on ebay oem in a mercedes box, for $302 shipped. you can tell if there real or not cause they have the mercedes symbol in the corner bottom by the trunk lid
Old Jan 11, 2007 | 09:05 PM
newton22's Avatar
BMW E39
Am I the only one who likes the pre-facelift tails better? They have that dated subtle look I like.
Old Jan 12, 2007 | 07:35 AM
Mark_K's Avatar
2002 S430
I paid 142.50 for mine. Here is the link
http://cgi.ebay.com/ebaymotors/ws/eB...m=110073246838
These are not OEM but should work out ok. I am installing them later today or tomorrow.
Old Jan 12, 2007 | 11:30 AM
02S430's Avatar
W220 M113K
looks good, good luck! it look much better!
Old Jan 12, 2007 | 06:02 PM
Mark_K's Avatar
2002 S430
OK all done!
I had to first supper glue the black plastic strip that you can see from the trunk to the light on one of the lights!!!!!!
And also had to trim some plastic in order to get one of the bulbs in.
Mine came with the LED lights in already and with the main bulb.
However, for $142.50 it looks nice.
So my mods to-date:
Tail lights, side mirrors and wood **** knob.
Old Jan 12, 2007 | 06:09 PM
02S430's Avatar
W220 M113K
get some pics up! lol
Old Jan 12, 2007 | 06:34 PM
Mark_K's Avatar
2002 S430
I will do some pics tomorrow.
What type of head lights did you upgrade to? Halogen or HID?
Old Jan 13, 2007 | 10:25 AM
Aleksandar's Avatar
2000 S500
Dang, I happen to like the fatties better I'm a fatty lover, I know. But, everyone who's done the mod, your cars look great. I guess I'm just not that cool.
Old Jan 13, 2007 | 12:08 PM
02S430's Avatar
W220 M113K
halogen
Old Jan 14, 2007 | 09:04 PM
Mark_K's Avatar
2002 S430
halogen
Great!
Now for some details.....
1. Where did you buy them?
2. Are they OEM?
3. Do you have a link?
4. How much did you pay?
5. Are you happy with the way the shine at night?
